Breaking down 32 output's into 4 separate ports
Hi,
·I've been playing around with a keyboard scan routine for some time now . Say you break up the 32 outputs into 4 separate sections , say 0..7 port one,· 8..15 port two, ect . I'm trying to make out0 high then shift left to out1 , I don't want to go any further than out7 and I want to start over again.
·I have experimented with using TEST , CMP and MAX·but It's seems like I end up with alot of extra code. Is there a simple way to JMP back to out0 after shift left reaches out7 ?
Thank's Brian
·"Imagination is more important than knowledge..." ·· Albert Einstein
www.PropelX.com
www.NorthStarMachining.com
Thank's Brian
www.PropelX.com
Shawn
Thank's Brian
www.PropelX.com
Post Edited (Brian Beckius) : 7/29/2008 2:30:18 AM GMT
I just·tested this with the demo board LED's, and it appears to do what I think you want it to do.
CON _clkmode = xtal1 +pll16x _xinfreq = 5_000_000 PUB Shift_Test cognew(@ShiftTest, 0) repeat DAT org 0 ShiftTest mov LEDs_OUT, #%00000001 shl LEDs_OUT, #16 mov LEDs_DIR, #%11111111 shl LEDs_DIR, #16 mov dira, LEDs_DIR mov time, cnt add time, delay MainLoop waitcnt time, delay cmp LEDs_OUT, Limit wc if_c shl LEDs_OUT, #1 if_nc shr LEDs_OUT, #7 mov outa, LEDs_OUT jmp #MainLoop Limit long %00000000_10000000_00000000_00000000 delay long 40_000_000 LEDs_OUT res 1 LEDs_DIR res 1 time res 1
Beau Schwabe
IC Layout Engineer
Now that opens the door up to having cog1 shifting 0..7 cog2 shifting 8..15 ,cog3 shifting 16..23 and cog4 shifting 24..31 ( I don't need the code for that, now that you have me over the hump).
Is adding delay to the time just to be safe ? I see in a lot of sample programs that only add $FF to the time.
Thank's Brian
www.PropelX.com
