Sharp IR Ranger noise!
Hello all,
I need some help with the noise that my IR ranger is making. I have an EmicTTS module hooked up to my bot along with the ranger, and whenever the Emic's not talking there is noise that is coming from the ranger, like a high-pitched beeping of about 15 beeps per second. How can I cancel this noise?
Robofreak
Austin Bowen,
Robo-freak.com
www.livesoundforum.com
"One must watch out for mechanics. They start out with a sewing machine, and end up with the atomic bomb" - A quote from someone that I saw on Addall.com
Robofreak
Austin Bowen,
Robo-freak.com
Austin Bowen,
Robo-freak.com
Austin Bowen,
Robo-freak.com
Austin Bowen,
Robo-freak.com
Austin Bowen,
Robo-freak.com
I would also put bypass caps .01 - 1uf (experiment) right at the power rails for the amp.
Lastly, that audio amp circuit is good for higher voltage (6-9v ideally, actually) -- you may want to try running the amp from your 7.2vin. You could try running the amp without the bypass cap between 1 and 8 (I'm wondering if you've got too much gain -- I've obtained plenty of volume w/o the bump in gain). Also, aren't you missing the series resistor w/the cap on pin 7?
For what it's worth, in noisy environments (like a 'bot) it took me some doing to eliminate noise in LM386 based audio amps. Short traces, tight connections, caps on power rails, all were necessary. Ditto proper routing (and sometimes shielding) of the speaker wiring (the wiring can act like a big antenna).
Austin Bowen,
Robo-freak.com
Either do this or add another regulator to the audio amp, you don't want the Ir stage and the audio amp stage running off of the same regulator.
Using separate regulators on individual stages is an effective way to isolate your DC supplies from feeding back to successive stages in your designs.
