SUBs, FUNCs, #s of Parameters
I have a couple of related questions regarding SUB and FUNC.
I have read the SX/B Help and have included part of the program
for the I2C experiment therein.
SUB min, max -- min is the minimum number of required Parameters, max is the maximum number of required parameters.
FUNC Return Count, Min, Max -- min is the minimum number of
parameters passed to the FUNCtion, max is the maximum number of
parameters passed to the FUNCtion.
Given:
MEM_OUT· SUB· 3
... and ...
SUB MEM_OUT has __WPARAM12, __PARAM3, tmpW1, tmpB1.·
Which are the parameters (re. min = 3)?· Are they "__WPARAM12, __PARAM3"; min = #parameters + 1 (n+1)?· Is it 3 because __WPARAM is a Word (2 bytes) and __PARAM is 1 byte, 2+1=3?
Given:
MEM_IN· FUNC· 1,2
... and ...
FUNC MEM_IN has __WPARAM12, tmpW1, tmpB1.·
Which are the parameters (re. min = 2)?· Is it __WPARAM12 (n+1)?· Is it 2 because __WPARAM12 is a Word (2 bytes)?
Given:
MEM_OUT· SUB· 3
... and ...
Given:
MEM_IN· FUNC· 1,2
... and ...
' --------------------------------- ' Variables ' --------------------------------- addr VAR Word addrLo VAR addr_LSB addrHi VAR addr_MSB outVal VAR Byte inVal VAR Byte tmpW1 VAR Word tmpB1 VAR Byte tmpB2 VAR Byte tmpB3 VAR Byte tmpB4 VAR Byte [color=red]MEM_OUT SUB 3 ' *********** MEM_IN FUNC 1,2 ' ***********[/color] SUB MEM_OUT tmpW1 = __WPARAM12 tmpB1 = __PARAM3 I2CSTART SDA tmpW1_MSB = tmpW1_MSB & $03 tmpW1_MSB = tmpW1_MSB << 1 tmpW1_MSB = tmpW1_MSB | SlaveID tmpW1_MSB.0 = 0 I2CSEND SDA, tmpW1_MSB I2CSEND SDA, tmpW1_LSB I2CSEND SDA, tmpB1 I2CSTOP SDA ENDSUB FUNC MEM_IN tmpW1 = __WPARAM12 I2CSTART SDA tmpW1_MSB = tmpW1_MSB & $03 tmpW1_MSB = tmpW1_MSB << 1 tmpW1_MSB = tmpW1_MSB | SlaveID tmpW1_MSB.0 = 0 I2CSEND SDA, tmpW1_MSB I2CSEND SDA, tmpW1_LSB I2CSTART SDA tmpW1_MSB.0 = 1 I2CSEND SDA, tmpW1_MSB I2CRECV SDA, tmpB1, Nak I2CSTOP SDA RETURN tmpB1 ENDFUNC
Bean.
"A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
"It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
www.iElectronicDesigns.com
PJ,
I think the word "parameters" can be somewhat misleading because, as you are asking, what makes a parameter? In this context a parameter is a byte that is passed. Therefore, the min and max values refer to the number of bytes that are passed into the subroutine.
Requires three bytes be passed to the subroutine. If you fail to pass at least three bytes when calling it the compiler should warn you of this condition.
NOTE: Because you have not specified a maximum number of bytes you can pass more than three if you like.
Inside the subroutine you can access the three bytes (or possibly more) in any way that makes sense to you and your program.
__PARAM1 holds the value of the first byte.
__PARAM2 holds the value of the second byte.
__PARAM3 holds the value of the third byte.
__PARAM4 might hold the value of the fourth byte if you passed one in.
__PARAM5 might hold the value of the fifth byte if you passed one in. (See the additional comments following this post.)
__WPARAM12 holds the value of the first two bytes together as a word value.
__WPARAM23 holds the value of the second and third bytes together as a word value.
__WPARAM34 holds the value of the third and fourth bytes together as a word value.
__WPARAM45 holds the value of the fourth and fifth bytes together as a word value.
Normally it makes the most sense to refer to the parameters according to the type of data being passed into the subroutine, meaning you use the corresponding byte parameter where you expect a byte and a word parameter where you expect a word value. But those parameters are just assigned aliases for the data in those positions. If you pass in three bytes of data you could access those values using __WPARAM12 to access the first two bytes together as a word and __WPARAM23 to access the second and third bytes together as a word. However, unless your program is extremely clever that probably will not make good programming sense. But you can still do it. You can also pass in a word value and access the data in the subroutine separately as two distinct bytes. There are cases when this may be helpful.
With this definition you can must pass in a byte, two bytes or a word variable but nothing or possibly more. The 1 states that at least one byte is required will be returned and the 2 states that at most least two bytes can must be transfered in. The key to understanding what can be passed is to understand the number of bytes represented. (And to recognize that a FUNC declaration starts by specifying the number of bytes returned while a SUB declaration starts with the minimum number of bytes that must be passed into it.)
Since the discussion has been about the subroutine parameter aliases I should point out the importance of using or reassigning these values almost immediately in the subroutine. Many of the more complex SX/B commands actually use those temporary addresses for their own needs and in the process overwrite the values that were originally passed in. Therefore be sure to reassign them to more suitable variable spaces (as you have already done) unless you are certain they will remain intact until needed.
I hope this makes sense.
- Sparks
[noparse][[/noparse]Edited to more accurately reflect the corrections mentioned below.]
Post Edited (Sparks-R-Fun) : 7/25/2008 4:31:34 AM GMT
In a FUNC (like MEM_IN), the first value is the number of bytes returned, the second is the minimum bytes the function will accept, the third (if used) is the maximum number of bytes the function will accept. So, the declaration of MEM_IN that you cite above is stating that it will return one byte and expects you to pass two bytes (a word) to it; the word value is the address within the device, the return value is the byte that was read from that address.
PJ -- one clarification regarding __PARAM5. __PARAM5 is an alias of __PARAMCNT, which is really the more useful of the two. __PARAMCNT is available to the sub/func and is a count of BYTES in the parameters. So you can have subs/funcs that accept a flexible number of byte parameters and which parse the count at the start of the subroutine to decide how to proceed.
__PARAM5 will only hold an actual fifth param byte if the sub/func is passed 5 bytes (the max allowed param count for any SX/B subroutine), in which case there is no param count.
So if the sub/func only allows 2 parameters, then __PARAMCNT will NOT be set to two.
Also __PARAM5 can only be used IF the sub/func expects exactly 5 parameter bytes.
Bean.
I am enlightened!
- Sparks
