Higher output from stepper motor controller...HELP....
I picked up one of those stepper controllers.. the ones that run of the parallel port of·a PC and control four motors... the only problem that I now have is the fact that the controller will only supply a maximum of 2.5A per phase.... my dear old steppers, bipolar with four wires, that I have need 8A.... I can run the motors with the controller per say, however I and easily.. as one would expect hold and stop the shaft of the motor while its running.. this is very not desirable... the question I ask is this... can I stack another H-Bridge on the output side of the controller to up the amperage rating of the controller, in other words... amplify the amperage output of the controller by adding to its outputs a circuit that does so.. anyone have any ideas and/or hints... please post schematics, links to schematics, or ideas... I really like this controller, and how it interfaces yet need to up it output current capabilities... HELP... Rob
- Stephen
If it's just TIP-31 and TIP-42's in an H-Bridge configuration, then potentially you could just take the control signals out to more powerful mosfets, like Franklin said.
