What type and where to buy xBee modules from.
Hello, I am looking into buying a pair of xBee modules to communicate between my computer and my BS2 and eventually, potentially a network connecting several BS2s. So my question is where is the best place to buy the modules (preferably not pro purely because the others are cheaper) and also the components i need to connect them to my pc and my BS2. Preassembled stuff would be great.
Sparkfun has the regular XBees in stock right now, except for the one with the wire antenna.
Your choice of CTS and DTR intrigues me. What led you to this particular combination instead of, say, CTS and RTS (for handshaking) or RTS and DTR (for reconfiguring the XBee)?
'Still some PropSTICK Kit bare PCBs left!
I would agree with everyone else. get them from digi key or spark fun but definitively get the carrier board from Selmaware, it take the hassle out of connecting them. they also incorporate LED's so it's easy to tell if your sending and receiving.
before you order I'd consider your project, is it going to be enclosed or in the open, there are 3 versions of the pro that I know of, Wire antenna, Chip antenna and one with a mini BNC connector to connect an external antenna. I have a project in an enclosure and I wish I would have know an external antenna was an option. and i prefer the chip antenna to the wire, the wire antenna gets bent and it's just a matter of time before it breaks.
I was able to buy just 2 X-bee pro modules and get them working. you won't need the board to configure them. unless you want to set them up for the mesh network or to a PC.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
I did use RTS / CTS after all, sorry. It's been so long since I actually wired it up that I got things mixed up.
Thanks, Mike!
The newer -B version has certain advantages if you plan to set up a self-organizing mesh network, but it won't give you point to point communication out of the box. It requires a coordinator to start the network, and to get a coordinator, you have to reflash the firmware.
Tracy Allen
www.emesystems.com
At Digikey and Mouser·they're labelled "XBee" and "XBee Series 2".
