FullduplexSerial Object
I am working on a fire alarm system.· Each module will talk to the next one to find the status, therefore each module needs two serial ports.· One to respond the the module "upstream" and one to talk to the next module.· What are the different modes in the FullDuplexSerial object do?· I need to wire the RX of one to the TX of the other.· So far I dont seem to get it right.
Thanks for the help
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
Buzzer = 0
AlarmSwitch = 9
MasterRst = 10
ID_Bit1 = 16
ID_Bit2 = 17
ID_Bit3 = 18
ID_Bit4 = 19
RX_1 = 20
TX_1 = 21
RX_2 = 22
TX_2 = 23
OBJ
SerialComm_1 : "FullDuplexSerial"
SerialComm_2 : "FullDuplexSerial"
VAR
LONG Unit_ID
LONG Alarm
LONG Comm1_Cog, Comm2_Cog, Alarm_Cog
LONG stack[noparse][[/noparse]120]
LONG Command[noparse][[/noparse]20]
PUB Main
System_INI
Comm1_Cog := cognew(Serial1, @stack[noparse][[/noparse]0]) + 1
Comm2_Cog := cognew(Serial2, @stack[noparse][[/noparse]40]) + 1
Alarm_Cog := cognew(SetAlarm, @stack[noparse][[/noparse]80]) + 1
ScanSwitch
PRI System_INI
dira[noparse][[/noparse]ID_Bit1] := 0
dira[noparse][[/noparse]ID_Bit2] := 0
dira[noparse][[/noparse]ID_Bit3] := 0
dira[noparse][[/noparse]ID_Bit4] := 0
Unit_ID := 0
if ina[noparse][[/noparse]ID_Bit1] == 0
Unit_ID += 1
if ina[noparse][[/noparse]ID_Bit2] == 0
Unit_ID += 2
if ina[noparse][[/noparse]ID_Bit3] == 0
Unit_ID += 4
if ina[noparse][[/noparse]ID_Bit4] == 0
Unit_ID += 8
bytefill(@Command, 0, 40)
Alarm := 0
PRI Serial1 | Buffer_1[noparse][[/noparse]10], Index, count
SerialComm_1.start(RX_1, TX_1, 0, 9600)
repeat
bytefill(@Buffer_1, 0, 20)
repeat Index from 0 to 20
Buffer_1.byte[noparse][[/noparse]Index] := SerialComm_1.rx
if Buffer_1.byte[noparse][[/noparse]Index] == 0
quit
if Buffer_1.byte[noparse][[/noparse]0] == "<" and Buffer_1.byte[noparse][[/noparse]1] == "S" and Buffer_1.byte[noparse][[/noparse]2] == ">"
SerialComm_1.str(@RequestRcv)
if Buffer_1.byte[noparse][[/noparse]0] == "<" and Buffer_1.byte[noparse][[/noparse]1] == "F"
repeat count from 0 to 40
Command.byte[noparse][[/noparse]count] := Buffer_1.byte[noparse][[/noparse]count]
Alarm := 1
if Buffer_1.byte[noparse][[/noparse]0] == "<" and Buffer_1.byte[noparse][[/noparse]1] == "T" and Buffer_1.byte[noparse][[/noparse]2] == ">"
Alarm := 2
PRI Serial2 | Buffer_2[noparse][[/noparse]10], MyCount, Index, FlagCount
SerialComm_2.start(RX_2, TX_2, 0, 9600)
MyCount := cnt
FlagCount := 0
repeat
bytefill(@Buffer_2, 0, 20)
if Alarm == 1 or Alarm == 2
SerialComm_2.str(Command)
if (cnt - MyCount) / clkfreq > 4
SerialComm_2.str(@SendRequest)
Buffer_2.byte[noparse][[/noparse]Index] := SerialComm_2.rxtime(20)
if Buffer_2.byte[noparse][[/noparse]Index] == 0
quit
if Buffer_2.byte[noparse][[/noparse]0] == "<" and Buffer_2.byte[noparse][[/noparse]2] == "R" and Buffer_2.byte[noparse][[/noparse]3] == ">"
FlagCount := 0
else
FlagCount ++
if FlagCount > 3
Alarm := 3
PRI ScanSwitch
dira[noparse][[/noparse]AlarmSwitch] := 0
dira[noparse][[/noparse]MasterRst] := 0
repeat
if ina[noparse][[/noparse]AlarmSwitch] == 0
Command.byte[noparse][[/noparse]0] := "<"
Command.byte[noparse][[/noparse]1] := "F"
Command.byte[noparse][[/noparse]2] := (Unit_ID / 10 ) + 48
Command.byte[noparse][[/noparse]3] := (Unit_ID // 10 ) + 48
command.byte[noparse][[/noparse]4] := ">"
Alarm := 1
if ina[noparse][[/noparse]MasterRst] == 0
Alarm := 0
PRI SetAlarm
dira[noparse][[/noparse]Buzzer] := 1
repeat
if Alarm == 0
outa[noparse][[/noparse]Buzzer] := 0
if Alarm == 1
outa[noparse][[/noparse]Buzzer] := 1
if Alarm == 2
!outa[noparse][[/noparse]Buzzer]
waitcnt(clkfreq / 2 + cnt)
if Alarm == 3
waitcnt(clkfreq / 4 + cnt)
waitcnt(clkfreq * 2 + cnt)
DAT
SendRequest byte "<S>", 0
RequestRcv byte "<R>", 0
Tornado byte "<T>", 0
Thanks for the help
As long as you have the third and fourth 0 and 9600 the same it should work. Look at simple_serial. For some reason it has the modes explained in the notes better than the fullduplexserial does.
