FullduplexSerial Object
I am working on a fire alarm system.· Each module will talk to the next one to find the status, therefore each module needs two serial ports.· One to respond the the module "upstream" and one to talk to the next module.· What are the different modes in the FullDuplexSerial object do?· I need to wire the RX of one to the TX of the other.· So far I dont seem to get it right.
Thanks for the help
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 Buzzer = 0 AlarmSwitch = 9 MasterRst = 10 ID_Bit1 = 16 ID_Bit2 = 17 ID_Bit3 = 18 ID_Bit4 = 19 RX_1 = 20 TX_1 = 21 RX_2 = 22 TX_2 = 23 OBJ SerialComm_1 : "FullDuplexSerial" SerialComm_2 : "FullDuplexSerial" VAR LONG Unit_ID LONG Alarm LONG Comm1_Cog, Comm2_Cog, Alarm_Cog LONG stack[noparse][[/noparse]120] LONG Command[noparse][[/noparse]20] PUB Main System_INI Comm1_Cog := cognew(Serial1, @stack[noparse][[/noparse]0]) + 1 Comm2_Cog := cognew(Serial2, @stack[noparse][[/noparse]40]) + 1 Alarm_Cog := cognew(SetAlarm, @stack[noparse][[/noparse]80]) + 1 ScanSwitch PRI System_INI dira[noparse][[/noparse]ID_Bit1] := 0 dira[noparse][[/noparse]ID_Bit2] := 0 dira[noparse][[/noparse]ID_Bit3] := 0 dira[noparse][[/noparse]ID_Bit4] := 0 Unit_ID := 0 if ina[noparse][[/noparse]ID_Bit1] == 0 Unit_ID += 1 if ina[noparse][[/noparse]ID_Bit2] == 0 Unit_ID += 2 if ina[noparse][[/noparse]ID_Bit3] == 0 Unit_ID += 4 if ina[noparse][[/noparse]ID_Bit4] == 0 Unit_ID += 8 bytefill(@Command, 0, 40) Alarm := 0 PRI Serial1 | Buffer_1[noparse][[/noparse]10], Index, count SerialComm_1.start(RX_1, TX_1, 0, 9600) repeat bytefill(@Buffer_1, 0, 20) repeat Index from 0 to 20 Buffer_1.byte[noparse][[/noparse]Index] := SerialComm_1.rx if Buffer_1.byte[noparse][[/noparse]Index] == 0 quit if Buffer_1.byte[noparse][[/noparse]0] == "<" and Buffer_1.byte[noparse][[/noparse]1] == "S" and Buffer_1.byte[noparse][[/noparse]2] == ">" SerialComm_1.str(@RequestRcv) if Buffer_1.byte[noparse][[/noparse]0] == "<" and Buffer_1.byte[noparse][[/noparse]1] == "F" repeat count from 0 to 40 Command.byte[noparse][[/noparse]count] := Buffer_1.byte[noparse][[/noparse]count] Alarm := 1 if Buffer_1.byte[noparse][[/noparse]0] == "<" and Buffer_1.byte[noparse][[/noparse]1] == "T" and Buffer_1.byte[noparse][[/noparse]2] == ">" repeat count from 0 to 40 Command.byte[noparse][[/noparse]count] := Buffer_1.byte[noparse][[/noparse]count] Alarm := 2 PRI Serial2 | Buffer_2[noparse][[/noparse]10], MyCount, Index, FlagCount SerialComm_2.start(RX_2, TX_2, 0, 9600) MyCount := cnt FlagCount := 0 repeat bytefill(@Buffer_2, 0, 20) if Alarm == 1 or Alarm == 2 SerialComm_2.str(Command) if (cnt - MyCount) / clkfreq > 4 SerialComm_2.str(@SendRequest) repeat Index from 0 to 20 Buffer_2.byte[noparse][[/noparse]Index] := SerialComm_2.rxtime(20) if Buffer_2.byte[noparse][[/noparse]Index] == 0 quit if Buffer_2.byte[noparse][[/noparse]0] == "<" and Buffer_2.byte[noparse][[/noparse]2] == "R" and Buffer_2.byte[noparse][[/noparse]3] == ">" FlagCount := 0 else FlagCount ++ if FlagCount > 3 Alarm := 3 PRI ScanSwitch dira[noparse][[/noparse]AlarmSwitch] := 0 dira[noparse][[/noparse]MasterRst] := 0 repeat if ina[noparse][[/noparse]AlarmSwitch] == 0 Command.byte[noparse][[/noparse]0] := "<" Command.byte[noparse][[/noparse]1] := "F" Command.byte[noparse][[/noparse]2] := (Unit_ID / 10 ) + 48 Command.byte[noparse][[/noparse]3] := (Unit_ID // 10 ) + 48 command.byte[noparse][[/noparse]4] := ">" Alarm := 1 if ina[noparse][[/noparse]MasterRst] == 0 Alarm := 0 PRI SetAlarm dira[noparse][[/noparse]Buzzer] := 1 repeat if Alarm == 0 outa[noparse][[/noparse]Buzzer] := 0 if Alarm == 1 outa[noparse][[/noparse]Buzzer] := 1 if Alarm == 2 !outa[noparse][[/noparse]Buzzer] waitcnt(clkfreq / 2 + cnt) if Alarm == 3 outa[noparse][[/noparse]Buzzer] := 1 waitcnt(clkfreq / 4 + cnt) outa[noparse][[/noparse]Buzzer] := 0 waitcnt(clkfreq * 2 + cnt) DAT SendRequest byte "<S>", 0 RequestRcv byte "<R>", 0 Tornado byte "<T>", 0
Thanks for the help
As long as you have the third and fourth 0 and 9600 the same it should work. Look at simple_serial. For some reason it has the modes explained in the notes better than the fullduplexserial does.
