Can someone explain the difference between an H-Bridge and the SN754410 chip?
Sorry if that question is stupid, I'm new to this whole robotics/electronics thing. I've been a programmer for a while, so my biggest hurdle is learning how all of these things play together.
Chris Savage
Parallax Tech Support
- Stephen
In sum, there are a lot of applications that find low power half and full H-bridges useful. In that context, the IC is great.
But if you really want to control a hefty DC motor, discrete components allow for dumping heat build up within the final stage. There are digital ways around this with MOSfets and PWM, but sometimes discrete components just can really handle more power.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
http://focus.ti.com/docs/prod/folders/print/sn754410.html
Thanks for the answer Kramer. So the H-Bridge would be better in high load applications because it could dissipate heat easier?
Two half H-bridges can be used to make a complete H-bridge.
Half H bridges can nicely control a stepper motor that requires the coils to be sequenced.
