Prop+ethernet example...
Hi all,
Well, I'm trying to get a simple "hello world" working showing how to create a tcp/ip server. I've taken code from around, and have created my first test showing a server waiting on port 80 (web)...and just waits for a connect...then I can expand that.
Unfortunately, it does not wait, it always "connects"...
...me thinks (me knows!
) I've done something wrong!
Here is the sample code
Looking at the code for the
it does not look like it blocks, hence the repeat...
All I have set my IP's...etc...
Thoughts?
~Kam (^8*
) I've done something wrong!Here is the sample code
' simple ethernet test
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
term : "TV_Text"
settings : "settings"
nic : "driver_socket"
DAT
MAC BYTE $de, $ad, $be, $ef, $ca, $fe
IP BYTE 10, 200, 1, 142
MASK BYTE 255, 255, 255, 0
GATEWAY BYTE 10, 200, 1, 1
DNS BYTE 10, 0, 0, 1
VAR
long stack[noparse][[/noparse]100]
PUB init | i
settings.start
settings.setData(settings#NET_MAC_ADDR,@MAC,6)
settings.setData(settings#NET_IPv4_ADDR,@IP,4)
settings.setData(settings#NET_IPv4_MASK,@MASK,4)
settings.setData(settings#NET_IPv4_GATE,@GATEWAY,4)
settings.setData(settings#NET_IPv4_DNS,@DNS,4)
' Start the TV Terminal
term.startWithMode(12,term#MODE_NTSC)
if settings.getData(settings#NET_MAC_ADDR,@stack,6)
term.str(string("MAC : "))
repeat i from 0 to 5
if i
term.out("-")
term.hex(byte[noparse][[/noparse]@stack][i],2)
term.out(13)
if settings.getData(settings#NET_IPv4_ADDR,@stack,4)
term.str(string("IP : "))
repeat i from 0 to 3
if i
term.out("-")
term.out(13)
if settings.getData(settings#NET_IPv4_MASK,@stack,4)
term.str(string("Mask : "))
if i
term.out("-")
term.out(13)
if settings.getData(settings#NET_IPv4_GATE,@stack,4)
term.str(string("Gateway : "))
if i
term.out("-")
term.out(13)
if settings.getData(settings#NET_IPv4_DNS,@stack,4)
term.str(string("DNS : "))
if i
term.out("-")
term.out(13)
' lets start the nic services
' p0 = cs
' p1 = sck
' p2 = si
' p3 = so
' p4 = int
' p5 = *NOTHING CONNECTED*
if not \nic.start(0, 1, 2, 3, 4, 5)
term.str(string("Unable to start networking!"))
waitcnt(clkfreq*10000 + cnt)
reboot
term.str(string("Networking Started"))
term.out(13)
term.str(string("Listening on port 80"))
term.out(13)
' lets wait for a connetion
repeat while \nic.listen(80) == -1
term.str(string("Connected!"))
term.out(13)
[/i][/i][/i][/i][/i]
Thoughts?
~Kam (^8*
So do something like this:
PUB main | handle repeat handle := \sock.listen(80) repeat until \sock.isConnected(handle) ' your normal handler stuff here sock.writeByte(handle, "H") \sock.close(handle)EDIT: Changed writeByte example. I forgot it only writes one byte...
Post Edited (Harrison.) : 7/18/2008 12:47:17 AM GMT
' lets start the nic services ' p0 = cs ' p1 = sck ' p2 = si ' p3 = so ' p4 = int ' p5 = *NOTHING CONNECTED* if not \nic.start(0, 1, 2, 3, 4, 5) term.str(string("Unable to start networking!")) waitcnt(clkfreq*10000 + cnt) reboot term.str(string("Listening on port 80")) term.out(13) repeat handle := \nic.listen(80) repeat until \nic.isConnected(handle) ' your normal handler stuff here nic.writeByte(handle, string("<html><body>Hello World!</body></html>")) nic.close(handle)Now it just sits and waits...
The plot thickens!
~Kam (^8*
Also, writeByte(...) only writes a single byte. You need api_telnet_serial.spin if you want to be able to use FullDuplexSerial style methods.
EDIT: You might want to add some more debug statements to see where it gets stuck.
Post Edited (Harrison.) : 7/18/2008 2:01:30 AM GMT
Well, smaller test program, same non-working issue
Here is the smaller code
' simple ethernet test CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ term : "TV_Text" settings : "settings" nic : "driver_socket" DAT MAC BYTE $10, $00, $00, $00, $00, $01 IP BYTE 10, 200, 1, 142 MASK BYTE 255, 255, 255, 0 GATEWAY BYTE 10, 200, 1, 1 DNS BYTE 10, 0, 0, 1 VAR long stack[noparse][[/noparse]100] long handle PUB init | i settings.start settings.setData(settings#NET_MAC_ADDR,@MAC,6) settings.setData(settings#NET_IPv4_ADDR,@IP,4) settings.setData(settings#NET_IPv4_MASK,@MASK,4) settings.setData(settings#NET_IPv4_GATE,@GATEWAY,4) settings.setData(settings#NET_IPv4_DNS,@DNS,4) settings.setData(settings#NET_DHCPv4_DISABLE, string("true"), 4) ' Start the TV Terminal term.startWithMode(12,term#MODE_NTSC) ' lets start the nic services ' p0 = cs ' p1 = sck ' p2 = si ' p3 = so ' p4 = int if not \nic.start(0, 1, 2, 3, 4, -1) ' -1 = use external clock term.str(string("Unable to start networking!")) waitcnt(clkfreq*10000 + cnt) reboot term.str(string("Listening on port 80")) term.out(13) repeat handle := \nic.listen(80) repeat until \nic.isConnected(handle) ' your normal handler stuff here term.str(string("Conected on port 80")) term.out(13) 'push "A" 10 times to client repeat 10 nic.writeByte(handle, 65) nic.close(handle)Looking thru the code, it looks like it will use dhcp if we tell it *NOT* to use it...I think I did the setting correctly...
So I want my ip to be 10.200.1.142...
I have not change any code in the driver etc...
Any thoughts why it does not connect?
~Kam (^8*
You could also add a check to make sure nic.listen(80) returns a valid handle. You can check for negative values (socket allocation errors) or just call nic.isValidHandle(handle) to let the code do all the internal checks.
Well, no luck so far...I've had nothing but computer problems all day!
So this is my latest code, it connects to the network (should use dhcp)
I try to connect to http://74.125.19.104 (one of googles servers) and just print the recieved data
But nothing! BLA!
Here is the complete code...
' simple ethernet test CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ term : "TV_Text" settings : "settings" nic : "driver_socket" DAT MAC BYTE $10, $00, $00, $00, $00, $01 IP BYTE 10, 200, 1, 142 MASK BYTE 255, 255, 255, 0 GATEWAY BYTE 10, 200, 1, 1 DNS BYTE 10, 0, 0, 1 REMOTEIP BYTE 74, 125, 19, 104 ' www.google.com VAR long stack[noparse][[/noparse]100] long handle byte rxChar PUB init | i settings.start settings.setData(settings#NET_MAC_ADDR,@MAC,6) ' set MAC settings.setData(settings#NET_IPv4_ADDR,@IP,4) ' set MY IP settings.setData(settings#NET_IPv4_MASK,@MASK,4) ' set MASK settings.setData(settings#NET_IPv4_GATE,@GATEWAY,4) ' set Gateway settings.setData(settings#NET_IPv4_DNS,@DNS,4) ' set DNS ' Start the TV Terminal term.startWithMode(12,term#MODE_NTSC) ' lets start the nic services ' p0 = cs ' p1 = sck ' p2 = si ' p3 = so ' p4 = int if not \nic.start(0, 1, 2, 3, 4, -1) ' -1 = use external clock term.str(string("Unable to start networking!")) waitcnt(clkfreq*10000 + cnt) reboot term.str(string("Connecting to http server...")) term.out(13) handle:=nic.connect(@REMOTEIP, 80, 80) term.str(string("Handle = ")) term.dec(handle) term.out(13) ' wait to connect term.str(string("Waiting to connect...")) term.out(13) repeat until nic.isConnected(handle) ' read in all the chars forever repeat rxChar:=nic.readByte(handle) term.out(rxChar)Any thoughts people?
AAHHHHHHHHHHHHH
~Kam (^8*
