Need a Self test. (Internet Netburner Kit)
Hi,
I need a self test because I need to know if
my Parallax Internet Netburner Kit is damage.
I am using it with a Basic Stamp.
Any Idea ?
Joe
Any Idea ?
Joe
- Stephen
I have some problems with connections.
It could be very usefull to have a self test rutine
that could run from a Stamp in order to test the
Internet Netburner Kit.
for example, LCD displays from Parallax have a self test
and it is very usefull.
Thanks, Joe
A typical session looks like:
Diagnostic display of Stamp to Netburner I/O
type logout to exit the monitoring session
W26: 07/17/08 15:42<CLS>]
Set Var [noparse][[/noparse]26] to [noparse][[/noparse] 07/17/08 15:42]
Received from stamp:[noparse][[/noparse]!NB0W20:30.11<CLS>]
Set Var [noparse][[/noparse]20] to [noparse][[/noparse]30.11]
Received from stamp:[noparse][[/noparse]!NB0W21:7.53<CLS>]
Set Var [noparse][[/noparse]21] to [noparse][[/noparse]7.53]
Received from stamp:[noparse][[/noparse]!NB0W22:7.72<CLS>]
Set Var [noparse][[/noparse]22] to [noparse][[/noparse]7.72]
Received from stamp:[noparse][[/noparse]!NB0W23:7.72<CLS>]
Set Var [noparse][[/noparse]23] to [noparse][[/noparse]7.72]
Received from stamp:[noparse][[/noparse]!NB0W24:7.02<CLS>]
Set Var [noparse][[/noparse]24] to [noparse][[/noparse]7.02]
Received from stamp:[noparse][[/noparse]!NB0W25: 96<CLS>]
Set Var [noparse][[/noparse]25] to [noparse][[/noparse] 96]
Received from stamp:[noparse][[/noparse]!NB0W27: 86.1<CLS>]
Set Var [noparse][[/noparse]27] to [noparse][[/noparse] 86.1]
Received from stamp:[noparse][[/noparse]!NB0W30: 30<CLS>]
Set Var [noparse][[/noparse]30] to [noparse][[/noparse] 30]
Received from stamp:[noparse][[/noparse]!NB0W31: 0.01<CLS>]
Set Var [noparse][[/noparse]31] to [noparse][[/noparse] 0.01]
Received from stamp:[noparse][[/noparse]!NB0W28: 47.9<CLS>]
Set Var [noparse][[/noparse]28] to [noparse][[/noparse] 47.9]
Received from stamp:[noparse][[/noparse]!NB0W26: 07/17/08 15:42<CLS>]
logouReceived from stamp:[noparse][[/noparse]!NB0W31: 0.01t<CLS>]
GoodBye
Connection to host lost.
There is already a test program included in the source code downloads from our website. This program verifies communication between the PINK Module and the BASIC Stamp by writing some data to some variables and then reading the data back and verifying it. What exactly are you experiencing? It’s not clear if you actually have a problem and if you do, which side it is on (BS2 or Network).
Chris Savage
Parallax Tech Support
