Decimal to binary translation help required
With the compass I just calibrated I wish to output the values to a three 7 segment LEDS. If you look at the code you can tell the I2C data is a decimal. A 7- segment display requires this value to be split and then translated into a binary or Hexidecimal. eg if the value is 1 then the output for a 7 segment display would be
either 00000110 or $06.
Can anyone help?
'{$STAMP BS2p}
'**··········· I2C Routines for the Basic Stamp····································· **
'**··········· using the CMPS01 Compass Module································ ·**
SDA··· CON· 8····· ' I2C data
SCL····· CON· 9····· ' I2C clock
SDAin··· VAR· IN8
SDAout· VAR· OUT8
SDAdir· VAR· DIR8
loop··· VAR· Byte····· ' just a looping counter
I2cBuf· VAR· Byte····· ' I2c read/write buffer
I2cAddr· VAR· Byte····· ' Address of I2C device
I2cReg· VAR· Byte····· ' Register number within I2C device
I2cData· VAR· Word····· ' Data to read/write
I2cAck· VAR· Bit····· ' Acknowledge bit
Main:
· I2cAddr = $c0····· ' CMPS01 Compass module address
· I2cReg = 1······· ' Bearing as 0-255 (BRAD)
· GOSUB· I2cByteRead
· DEBUG· 2,0,0, "Compass Bearing (0-255 BRAD)·· ", DEC3 I2cData
· I2cReg = 2······· ' Bearing as 0-359.9 degrees
· GOSUB· I2cWordRead
· DEBUG· 2,0,1, "Compass Bearing (0-359 Degrees ", DEC3 I2cData/10
· GOTO· main
I2cByteWrite:······· ' writes I2cData.lowbyte to I2cReg at I2cAddr
· GOSUB· I2cStart
· I2cBuf = I2cAddr
· GOSUB· I2cOutByte····· ' send device address
· I2cBuf = I2cReg
· GOSUB· I2cOutByte····· ' send register number
· I2cBuf = I2cData.LOWBYTE
· GOSUB· I2cOutByte····· ' send the data
· GOSUB· I2cStop
· RETURN
I2cWordWrite:······· ' writes I2cData to I2cReg at I2cAddr
· GOSUB· I2cStart
· I2cBuf = I2cAddr
· I2cBuf = I2cReg
· I2cBuf = I2cData.HIGHBYTE
· GOSUB· I2cOutByte····· ' send the data - high byte
· GOSUB· I2cOutByte····· ' send the data - low byte
· GOSUB· I2cStop
· RETURN
I2CByteRead:
· GOSUB· I2cStart
· I2cBuf = I2cAddr
· I2cBuf = I2cReg
· GOSUB· I2cStart····· ' repeated start
· I2cBuf = I2cAddr | 1
· GOSUB· I2cOutByte····· ' send device address (with read set)
· I2cAck = 0······· ' send Nak
· GOSUB· I2cInByte
· I2cData.LOWBYTE = I2cBuf· ' read the data
· I2cData.HIGHBYTE = 0
· GOSUB· I2cStop
· RETURN
I2CWordRead:
· GOSUB· I2cStart
· I2cBuf = I2cAddr
· I2cBuf = I2cReg
· I2cAck = 1······· ' send Ack
· GOSUB· I2cInByte
· I2cData.HIGHBYTE = I2cBuf· ' read the data
· GOSUB· I2cInByte
· GOSUB· I2cStop
· RETURN
I2cOutByte:
· SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]I2cBuf]
· INPUT· SDA
· HIGH· SCL········· ' clock in the ack' bit
· LOW· SCL
· RETURN
I2cInByte:
· SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]I2cBuf]
· SDAout = 0
· SDAdir = I2cAck
· HIGH· SCL········· ' clock out the ack' bit
· LOW·· SCL
· INPUT· SDA
· RETURN
I2cStart··········· ' I2C start bit sequence
· HIGH· SDA
· HIGH· SCL
· LOW· SDA
· LOW· SCL
· RETURN
I2cStop:··········· ' I2C stop bit sequence
· LOW· SDA
· HIGH· SCL
· HIGH· SDA
· RETURN
Can anyone help?
'{$STAMP BS2p}
SDAin··· VAR· IN8
SDAout· VAR· OUT8
SDAdir· VAR· DIR8
Main:
· GOTO· main
· GOSUB· I2cStart
· I2cBuf = I2cAddr
· I2cBuf = I2cReg
· GOSUB· I2cStop
· RETURN
· GOSUB· I2cStart
· I2cBuf = I2cAddr
· I2cBuf = I2cReg
· GOSUB· I2cStop
· RETURN
I2CByteRead:
· GOSUB· I2cStart
· I2cBuf = I2cAddr
· I2cBuf = I2cReg
· GOSUB· I2cInByte
· GOSUB· I2cStop
· RETURN
I2CWordRead:
· GOSUB· I2cStart
· I2cBuf = I2cAddr
· I2cBuf = I2cReg
· GOSUB· I2cInByte
· GOSUB· I2cInByte
· GOSUB· I2cStop
· RETURN
I2cOutByte:
· INPUT· SDA
· LOW· SCL
· RETURN
I2cInByte:
· SDAout = 0
· SDAdir = I2cAck
· LOW·· SCL
· INPUT· SDA
· RETURN
· HIGH· SDA
· HIGH· SCL
· LOW· SDA
· LOW· SCL
· RETURN
· LOW· SDA
· HIGH· SCL
· HIGH· SDA
· RETURN
- Stephen
Cheers.
