Is it possible and legal to reproduce the signal of 4 GPS satalites in a whereh
I would like to do some experiments with GPS navigation indoors, but I don't know if it would cause problems outdoors or if I would need a permit?
Bill
Bill
What is your end goal in all of this, BTW? Maybe there's another way to get there.
'Still some PropSTICK Kit bare PCBs left!
Any other ideas?
http://en.wikipedia.org/wiki/Glideslope
GPS works on the delay for the signal to get from the satellites to the receiver.
With the signal being generated only meters away the delay wouldn't be large enough to triangulate the position.
You could try and make your own system using xbee's or something and go off signal strength but working out the position might be hard.
All I can say is good luck.
Building Blocks To The Propeller Chip A web site designed to help people who are new to the propeller chip.
Guitar Hero controller using the prop (WIP) --> HERE
I need to do more research.
I was realizing that while I was reading PJ Allens link.
What if I used·3 or 5 RF recievers-transmitters that were programed to respond to a signal after a programed delay (like the DME). That way the bot would always be able to measure the send - delay - return time in a predetermined order.·If·a Propeller counter, is able to make sense of the nano sec differences from 3 to 5 sequential sources?
Post Edited (Capt. Quirk) : 7/16/2008 2:25:10 AM GMT
http://forums.parallax.com/showthread.php?p=723969
