Parallax Servo Controller (USB) came in today
Hello
Am using Parallax Servo Controller for My new project.
Parallax Servo Controller (USB) Manual States
In general, servos require 4-7.5 VDC. Be sure that
the servo power source can supply ample current at the proper voltage and will not damage
the servos.
Im looking better power source. What do you recommend·? Is there a AC·power supply? Or what type of rechargeable batteries?
Last year My animatronic Project I used 2 Mini SSC II boards and chain them +·Battery Booster 12
The Booster allow me to use·rechargeable aa batteries.With 16 servos after about 15 mins power would quit.
http://www.youtube.com/user/willettfx
Parallax Servo Controller Came in today And I luv it.
Gary
willettfx.com
the servos.
Gary
willettfx.com
Post Edited (Mike Green) : 6/21/2008 10:22:01 PM GMT
Gary
http://www.willettfx.com
What software are you going to control it with?
I am trying to find support for the Parallax Servo Controller (USB) and the MicroSoft Robotics VPL. Does anyone have any information on that?
Jamie
http://www.brookshiresoftware.com/
VSA
Gary
willettfx.com
I had the same problem so i used GP D sized 5C 9500 mah batteries and thay work vary well
I work with FUTABA 3306 servos thay drain alot of power about 4.9A
i think you got to make sure that the batteries can take the load
have a good day
Any tips ,My OS is Vista, And this is first time setting up Parallax.
Im using a RadioShack Adaptaplug with 6V power supply.
When the USB is plug in I get a red light .I choose com port 3 in PSCI software and VSA software.
I do see the green light flash ,But no servo movement.
With the controller power off I turn the arm servo and turn power on the servo will go to center and this is the only
servo movement Im getting.
What is the jumper for?
What is the button above the jumper?
Thank you
Gary
http://www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html Cheapest 6V SLA in the world...
http://www.batterymart.com/p-6v-500ma-sealed-lead-acid-battery-charger-2.html· 6 Vfloat charger
Jeff T.
Im Working NOW!!!!
Gary
http://www.youtube.com/watch?v=UiynvPJPHbc
MY EYEBALL PROCESS PART 4
http://www.youtube.com/watch?v=hmk9PnFIWuY
Gary
Chris Savage
Parallax Engineering
Gary
