Guitar Hero Controller (project)
I have started this topic for discussion about my latest project which can be found at robot.tmcp.com.au/buildingblock/projects/guitar.htm.
Please feel free to leave comments or advice.
If you come up with a solution to a problem I have then I will be most happy.
Thank you
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Stickers for sale
Building Blocks To The Propeller Chip
Thank you
The Microchip MCP23016 is a 16-bit I2C I/O Expander that can be attached to the boot EEPROM lines, comes in a DIP package, and can drive up to 16 LEDs (at 15mA or so). There's sample code in the I2C Library object from the Propeller Object Exchange.
As you can see in the pics I uploaded to the site, the circuit board is really low on space and I require it to be single sided.
I will see what I can do about adding an I/O expander.
Thank you
It'll be a lot nicer to code than adding any pic chip [noparse]:D[/noparse]
As for space, can you use surface mount, and a double sided board?
Baggers.
Mount resistors vertically to save board area.
You need a couple of 0.1uF ceramic bypass capacitors for Vdd/Vss. You've got them for the Prop, but you might add them for the EEPROM and, for sure, for any I/O expanders.
Post Edited (Mike Green) : 7/13/2008 2:29:49 PM GMT
Using a second prop for nothing more than controlling leds seems like a waste considering the need for an external clock and eeprom.
Thank you anyway Baggers.
I have the resistors mounted horizontally to allow for the tracks to run under them.
Will put 0.1uf cap on eeprom and on any I/O expanders I add.
Would it be possible to put the I/O expander on a separate board and join them with a ribbon cable or would there be to much noise?
Will most likely have to do this with SD card as well.
I need to keep them single sided as I am making them myself with the Press-n-peel method.
Depending on the price I might get some boards made up if the home made ones work well.
I would like to take this time to thank you both for your contributions to the community, you have both done a lot to help everyone.
Thank you
Will it run at 3.3v with 10k pullups? Or does it need 5v?
edit: Also if I was to omit the INT connection should I connect it to VDD or VSS.
edit2: I have updated the web page with a correct pin usage table.
Will update the PCB pictures once I have made the modifications.
Thank you
Post Edited (computer guy) : 7/14/2008 3:46:55 AM GMT
INT is an output from the PCA9554. If you don't use it, leave it unconnected.
Thank you
edit: The led board will have a 240ohm resistor for each led and the 3v3 connection.
when the I/O pin is low the led will light when it is high led wont.
So 3v3---/\/\/\/----<|
Expander I/O
/\/\/\/\ = 240ohm resistor
<| = led
Thank you
Post Edited (computer guy) : 7/14/2008 6:00:43 AM GMT
Thank you for your help. However considering the lack of schematics and code on their site at the current time they don't provide much help.
I will continue to update my site with pictures and code and am planning on providing a step by step tutorial on how I make it.
edit:
For those interested in building one of their own without using my plans.
Here is the website that Nick provided in a reply that has now been deleted.
http://mechanizedrock.com/
Thank you for the link Nick.
Please note that the site above has nothing to do with my project.
Thank you
Post Edited (computer guy) : 7/14/2008 8:46:19 AM GMT
If you notice anything wrong with any of the boards please point it out to me.
Thank you
Building Blocks To The Propeller Chip A web site designed to help people who are new to the propeller chip.
Guitar Hero controller using the prop (WIP) --> HERE
Post Edited (computer guy) : 7/14/2008 12:28:48 PM GMT
edit: I have updated the main board image again as I decided a trimpot was needed on the ADC0831's REF pin.
Post Edited (computer guy) : 7/15/2008 9:35:57 AM GMT
If someone could take the time to look over them and make sure there isn't any obvious mistakes it would be nice.
Thank you
Post Edited (computer guy) : 7/22/2008 8:44:43 AM GMT
Coz I will be making these board in about a week.
Just a small amount of your time.
Thank you
- Does the I/O expander chip have built-in pull-up resistors? If not, the buttons could use some.
- Do your 3V and 5V regulator chips need input/output filter capacitors?
- Where are the pull-up resistors for the SD card slot?
--Micah
- Will look into the I/O expander and make changes if I need to.
- I was thinking that but am running low on space. Would some ceramic or tantalum caps do. They are small and would not take up much space but would they do the job?
- The SD card has a resistor network. This is shown as a rectangle and several lines in the schematic.
Thank you
Unless your regulators are specially designed to not need filter caps (I think there is one model by Burr-Brown that fits this description) you *do* need input and output caps. Check the regulator's data sheet, but it's usually best to put in both a 0.1uF cap (for high frequency rejection) and something larger.. in the tens or hundreds of uF range, depending on how noisy the input is and what kind of load you're driving.
As an example, the Parallax demo board uses a 0.1uF cap on the input of its 5V regulator, and 10uF caps on the regulated 5V and 3.3V outputs. Something like this should be reasonable for most applications, but definitely check the data sheet on your particular regulator chips.
If you get it working and post pictures, schematics, and code, I'm sure people will be interested- and they may even want to build their own.
You might also ponder doing a version of this which involves less mechanical construction, and just acts as a dongle that sits between a normal GH controller and the Playstation. It could accept SD cards, and have buttons for recording performances to the card or playing them back.
--Micah
