AppMod-compatible devices?
CounterRotatingProps
Greetings!
several N&V articles, for example #144, mention·a "Parallax AppMod-compatible device."
A search here turns up a lot about header pin outs, but not much about a spec. per se. The products pages and catalog don't mention such devices (of course, I could have missed seeing such!
Could you all describe this, or point to·a link about the concept?
thanks!
).Could you all describe this, or point to·a link about the concept?
thanks!
>> Look at the schematic
thanks, yes I will do that.
>> only a few devices that use it
Where might we find these?
Never have had·had a Bad Hair Day since meeting a Tesla coil.
wonder why the app-mod format is not more widely used?
thanks again for the fast reply!
from what I've read in the mean time,·it seems·that App-Mod is not only a pin out config, as Dr. Green mentioned, but also a Protocol.
Since Parallax has the header on board, is·the AppMod protocol is a Parallax-defined communication protocol and·is·it documented somewhere here? - it's hard to imagine its proprietary!
thanks
-Howard
Buzz Whirr Click Repeat
Did Mr. Williams create this idea - he mentions it so frequently in his Nut's and Volts articles (including fairly recent ones) that I assumed this was a widely accepted protocol. Nonetheless, it does seem like a clever solution. I'll be doing a far amount of R&D with RS-485 - it seem natural to adopt any standard already supported.
thanks,
-Howard
I have no idea who came up with it first at Parallax. It's not a new or unique idea, just nicely done.
Chris Savage
Parallax Tech Support
http://forums.parallax.com/showthread.php?p=716795
Hey, Howard.
Not quite sure where you read about this protocol but I have both the Modem AppMod and LCD Termianl AppMod and neither of these has any sort of common protocol. In each case you communicate directly with the hardware on the AppMod board according to that hardware's specifications, which don't follow this "AppMod protocol".
Just wanted to let you know about this--not all AppMod boards out there have this protocol.
The open true (pulled high, driven low) serial line means any number of devices can all share the same serial I/O line, and the addressing schema means you can address any device on the line. It's a pretty simple and effective way of adding lots of peripherals to a project with only a single dedicated host pin.
this is exactly what I wanted to know... and Zoot, the link is much appreciated. Interesting that one poster there mentinos that Parallax discontinued the appmod products some years ago, yet the most recent items are this year. It seems like a good idea at least in the sense that it might make it easier to understand someone else's code than if you were to roll your own, so to speak.
I'll dig around in that thread a while to learn more.
thanks again!
- Howard in Florida
