Stamp compatible serial printers
·Hi folks,
·· I've got an up-coming project which needs a small printer to issue a load slip or transaction ticket.
·· The Citizen CMP10, a serial thermal printer seems·reasonably suitable.
·· Has any one got a recommendation or an alternative?
·· Thanks,
Tom Sisk
http://www.siskconsult.com
·· Thanks,
Tom Sisk
- Stephen
Tom Sisk
I was trying to create full parity and handshaking with the SXes in assembly code an it became obvious why less and less devices are bothering with such.
Of course, if you are using a device that demand such, you can often cheat the device by using a jumper.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
Thanks for info.
Most of the printers I've used with stamps have been industrial serial printers. Generally very easy to work with....control codes and serial data out to the printer and printer status in via serial. Have used impact and thermal Zebra's and Star's but they are a bit pricey for this job.
Was really looking for some lower priced units that someone had actually driven from the Stamp.
I've located a couple of other likely suspects on ebay so may just pick them up and experiment.
Cheers,
Tom Sisk
www.zebra.com/id/zebra/na/en/index/products/printers/desktop/lp2844.html
~~ dRu ~~
