Underwater Sonar
LoopyByteloose
I have been thinking that it might be possible to create underwater sonar with hacking an ultrasound sensor to do most of the work.
The sensor would obviously need to be waterproofed for reception. But it one could use an underwater speaker driven by a power amp to boost the ping and have it driven by the ultrasonic sensors output. You might get some genuine DIY sonar.
The main rationale is that many tweaters will output in the ultrasound range even if they were not designed to do so. So creating a greater power output will allow measurement of greater distances.
Underwater speaker housings do exisit. So the only bit of trouble is getting the underwater ultrasound sensor to work.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
···················· Tropically,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
-phar
http://www.tigergps.com/garmin1043500.html?productid=garmin1043500&channelid=BIZRA
I would suggest you go to your a local sporting goods store that has a good supply of gadgets for fishermen.
Post Edited (MSDTech) : 7/7/2008 10:00:05 PM GMT
-phar
-phar
