How do you speed up the boe-bot motors?
Hi, I can make the motors go max speed on pulsout 650 and 850. I was wondering if there was a way to tweak the motors to go faster, or whether or not there are different motors that will fit on the boe-bot chassis that I can buy.
into them) you could switch them from VDD to VIN to get a little bit more power into the servos.
Like Mike said... if you use BOE-Boost with alkalines or a 9volt to power your BOE, don't do this... it'll cook your servos.
There's a jumper on most BOEs that's right between the two servo ports to do the job.
We have something coming which will give you 3x more speed, and fit within the Boe-Bot chassis. Unfortunately they're not cheap, but they'll certainly boost your bot.
Speeder, If you decide to add a 5th AA battery are you aware of this product?
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/List/1/ProductID/455/Default.aspx?txtSearch=BOE+Boost&SortField=ProductName%2cProductName·This is about as simple a solution as you could get.
Check out the pdf BOE Boost Documentation (link to this is on the page linked above). It will give you some info on the 7.5 volts for Alkaline batteries·vs. 6 volt for NiMH (rechargable) batteries·that Mike Green mentioned as well as the Vin (full battery voltage)·and Vdd (regulated voltage)·jumper. This jumper (located between the servo connection headers·on the Rev. C BOEs) Important - If you do go to Vin remember to change the setting of the jumper (back to Vdd)·before using a·9 volt battery or power supply·or you could damage your servos.
Whit+
Post Edited (Whit) : 7/10/2008 8:46:48 PM GMT
Ken, don't leave us hanging, how about a bench photo or even a description. [noparse]:)[/noparse]
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
