Recomend any 1-Wire humidity sensors?
I've been trying to find humidity sensors that work on 1-Wire and so far everything is big and expensive, was wondering if anyone knows about any relatively cheap humidity sensors in DIP size? Sensing temperature would be a plus, temperature alert wires (like the 1620) would close the deal. Thanks for any help!
He used a SHT15. Not sure of the price, but its one wire and gives RH as well as Temp.
- Stephen
Maybe half my words. Apparently there are devices about that are I2C-ish but don't call it "I2C" because they'd have to pay royalties to Phillips. Check out this discussion:
http://www.embeddedrelated.com/usenet/embedded/show/12389-1.php
(scroll down to the bottom if you want)
So does this mean the SHT15 is a device that acts like I2C? If someone could assure me that I can individually address a dozen SHT15's on the same set of Stamp pins, I would order them right now. They are expensive but I need lots of humidity readings for my application. Plus Parallax already goes through the trouble of putting it on a board that normal people can use. (Not that the DIY board Franklin recommended above isn't awesome!).
Tracy Allen
www.emesystems.com
- Stephen
Well, I'm sad now but I do appreciate all the info. Thanks much!
Franklin,
it "doesn't", but apparently with it's thermometers and some codery it can output a humidity-like value. It was mentioned as an aside in a tech article, if I find it again I'll put it up. In hindsight it's probably not very good data. (compared to the larger, purpose-made sensirion and it's heated sensor). But it looked workable in desperation.
Here's one of the articles I mentioned, using the DS2438 for humidity:
http://www.sensorsmag.com/sensors/Technologies+In+Depth/Sensors/Humidity/Moisture/A-1-Wire-Humidity-Sensor/ArticleStandard/Article/detail/361379
- Stephen
