Connecting a second servo to BS1 project board
Awhile back I began playing with a BS1 project board and built a voltage regulator on the breadboard part in order to operate a servo. My project goal has now expanded, and now I want to use an additional servo. Both servos will not be operating simultaneously so I don't think I should have any problems with powering the two of them. I need to know what exactly should be done to make this happen. Do I need to have a second voltage regulator, or can I use the same one for both servos? For reference please see this previous discussion thread which shows exactly how my original set up was constructed:
http://forums.parallax.com/forums/default.aspx?f=5&m=215628
If you have a pretty standard voltage regulator that can supply on the order of 1A and is powered from Vin or some other suitable source, and the one servo seems to work ok, then you should be able to add a 2nd servo to the same regulated supply, An idle servo doesn't draw much current. Peak current for a single servo is about 1A. Average current is maybe 250mA when the servo is moving under low load.
Also, take a look at this drawing someone made for me that gives an overview of this whole setup. Just ignore the car battery hookup since I am simply using a standard AC outlet. I need to now based on this current setup where or how I should add the other servo.
- Stephen
I'm not trying to sound snotty or rude, or like a know it all, I'm just trying to help you along the road to bigger and better. been there done that!
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
as far as connecting another servo, the Basic stamp 1 project board makes it really easy, all you need to do is soldier in another 3 pin connector to the board and your good to go, see this diagram for details http://forums.parallax.com/forums/attach.aspx?a=16827
just FYI, the power can be connected directly from one servo to the next, positive to positive, negative to negative. the I/o connection needs to be separated, and only one i/o line can connect to one servo. this is all done for you on the project board.
DGSwaner
If you want to stick with linear regulators, here are a few suggestions:
Servos can take more than 5 volts, so you could use an adjustable regulator like an LM317T to give them 7.5 or 8 volts for snappier action, plus, the regulator will run cooler than 5 volts (less drop). the LM317T is rated for 1.5 amps if you heat sink it.
If both servos may be on at the same time, you could give each its own regulator to spread the heat over twice the hardware. Same total heat given off, but less localization.
