What rechargeable battery type has the slowest self-discharge rate ?
Bean
I bought a solar powered flashlight (okay everybody laugh now and get it over with).
It had a 600mA AA ni-cad battery, I replaced that with a 2500mA ni-mh battery.
The solar panel only puts out about 40mA of charge current. So I'm worried that without constant sunlight the battery will lose alot of charge just from self-discharge.
What would be the best battery to use that has the slowest self-discharge rate.
The light uses about 180mA when it's turned on.
Bean.
Uhhhm, that was on fire when I got here...
www.iElectronicDesigns.com
Bean.
I've seen NiMH batteries in stores that come already charged and have a low self-discharge rate. I don't remember what they're called, but that's what you want.
Rick
It's Only A Stupid Question If You Have Not Googled It First!!
- Stephen
That might be a good candidate for your flashlight.
Yeah, less than 2% per month loss. That would be pretty good.
I'll check them out.
Bean.
Nexcell EnergyOn, Accupower Acculoop, Uniross Hybrio...
www.nimhbattery.com/eneloop-hybrio-acculoop-energyon-faqs.php
HTH
Most of today's rechargibles are designed for quick recharge and not longer term storage. This has come about by the desire to reduce the overall size and weight.
But the lead acid batteries are sometimes referred to as 'storage cells'
"The Art of Electronics" seems to confirm this.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
For reference, I took ~800 pictures (some flash, mostly not) with a Canon A710IS camera on less than 2 full charges. I used a set of batteries for a while (maybe 400 pics), then swapped them for a fresh set, charged a week before. The 2nd set are still good. I rarely get to the point of a low-battery indication. I used to use regular NiMH, and I found I had to charge them much more often.
Your mileage may vary...
I have an early digital and the real heart-break is the $40USD for a lithium battery that doesn't keep a charge very long. People naturally set a camera aside and then suddenly want it to work instantly for the sudden 'photo op'. In my case, the battery is usually dead.
I suspect there is a conspiracy by manufacturers of the AA, AAA, C, and D cells to always make NiMH more troublesome than Alkaline, After all, they really want you to keep buying their product and NOT save money.
Still, there may be a good reason that Bean's solar recharge flashlight had only a 600ma unit. The solar cell may never put out enough to charge a higher capacity unit. Rechargible batteries have both a minimum trickle and a maximum high rate charge.
I have use a few of these in my solar yard lights that are made with AA lithium solar battery
I have some solar yard lights that take 3 nicad batteries and have change them to the lithium solar battery and they seem to last longer than the NiMH or the Nicads batteries
I was amazed to find out that the ELT (emergency locator transmitter) in my Cessna is powered by a bunch of Duracell D cells. It's inspected every year, but they spec out a 5-year battery life. Too bad the FAA just changed the ELT frequency to 406 MHz and my 121.5 MHz unit from 1980 is a boatanchor now.
http://www.ebay.com/itm/151216202540
I just ordered one... but im not concerned about self-discharge for my needs, I need highest discharge rating as im limited in case size to 10mm diameter and need highest amperage output possible.
