Proptool bug with load EEPROM/RAM? — Parallax Forums
edited 2008-06-30 17:42 in Propeller 1
Is it my configuration or is there an issue with the load binary
to EEPROM/RAM options in the last two versions of Proptool?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
  • jazzedjazzed Posts: 11,803
    edited 2008-06-30 16:49
    What is failing ?
    edited 2008-06-30 17:31
    Either button just won't do anything...
    OBC
  • ColeyColey Posts: 1,130
    edited 2008-06-30 17:40
    Jeff,
    You are not alone, I too have experienced this, until now I thought it was my setup.
    My problem happens sometimes when I double click a binary file from windows, Proptool loads up but won't do anything.
    I close Proptool down and try again and it works....
    Coley
    Edit: after this bug manifests itself, I get an error message saying that there was a serious error on the comport.
    Closing the binary file and then opening it again solves the problem, my guess is the problem lies with usb adapter code.
    PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
    Post Edited (Coley) : 6/30/2008 5:45:45 PM GMT
    I noticed this happening in the last two releases... But until I borrowed a laptop
    for the weekend, I thought it was just my shop machine.
    I'll try the restart trick and see if it works..
    In the meantime, I've switched to having a copy of Proptool handy for ram loading.
    OBC
