Full Duplex Serial Question
Is there a maximum number of bytes you can send with Full Duplex Serial?
Example:
bytemove(@strptr,String("Hi, My name is Michael King and i am testing the Full Duplex Serial Object"),73)
FDS.str(@strptr)
E/
·- Was it pin 11 or 26?· Hmmm....··I think the smell of smoke tells the whole story.· Must be 26.
Michael King
Application Engineer
R&D
Digital Technology Group
Example:
FDS.str(@strptr)
E/
Michael King
R&D
In other words, there is no maximum number of bytes you can send with FullDuplexSerial. When you move a string to your own buffer (as in your example), make sure to include the terminating zero byte in the count. A string like "ABCD" is really 5 bytes in length if you include the terminator. In your example, you can transmit the constant string directly as in: FDS.str(string("ABCD"))
It has a configurable FIFO size, defaulted to 64 bytes (i think)
I was intermittently corrupting incoming 17-byte messages until I found this package.
Thanks again, Mike
