Setting Pointer?
Hello all.
I'm having trouble with saving stuff into global variables and passing values correctly. I'm currently using a modification of Servo32v3.spin for controlling DC motors. However, we can assume that I'm just using it. If you've never used it, it has a special PUB called Set(Pin, Width) to set the position of the encoder. However, after the object is running, the only thing that this object does is save the value to an array. What I'd like to do is to instead directly change that variable in the global memory. Here's an example:
Do this:
instead of
Here is PUB Set:
I tried to pass it a new variable @servopos[noparse]/noparse, but it didn't work. Does anyone have any suggestions? Greatly appreciated. Thanks.
Do this:
ServoData[noparse][[/noparse]Pin] := 1500
instead of
Servo.Set(Pin,1500)
Here is PUB Set:
PUB Set(Pin, Width) 'Set Servo value
Width := 0 #> Width <# 5000 'limit Width value between 1000uS and 2000uS
' Pin := 0 #> Pin <# 31 'limit Pin value between 0 and 31
ServoData[noparse][[/noparse]Pin] := (clkfreq / _1uS * Width) 'calculate # of clocks for a specific Pulse Width
dira[noparse][[/noparse]Pin] := 1 'set selected servo pin as an OUTPUT
ServoPinDirection := dira 'Read I/O state of ALL pins
It's certainly possible to add a method to the servo object that simply returns the address of the servo array ("return @ServoData") which you'd store in some variable, say "PP". To reference the array elements, you'd need to write "word[noparse][[/noparse] PP ][noparse][[/noparse] Pin ]" or "long[noparse][[/noparse] PP ] [noparse][[/noparse] Pin ]" depending on how the array is declared.
What I'd like to have happen is that I'd be able to reset my servo values from several different cogs. With the current method, it wasn't working. What I had to do was setup another cog that ran through and set all of the servo values.
PWM.Set(MRp,ph) 'Set PWM Pins PWM.Set(MLp,ph) PWM.Set(MCp,ph) PWM.Start repeat PWM.Set(MRp,Pr) PWM.Set(MLp,Pl) PWM.Set(MCp,Pc)But I'd rather set the new servo values directly.
I understand the bounds checking and other things that the servo.set function does and I can do that elsewhere. That last point you made I think was what I was looking for.
Though I'm not quite sure how I would implement it. Could you give me one more kick in the right direction? THanks
Craig
In your initialization just before you call Servo.Start, put "ServoDataPtr := Servo.getServoDataPtr". After that point (and after you call Servo.Start), you can do a "long[noparse][[/noparse] ServoDataPtr ][noparse][[/noparse] Pin ] := clkfreq / Servo#_1uS * Width" where "Width" is whatever pulse width you want and "Pin" is the servo pin number.
It doesn't matter what cog is executing this. If you have a separate object where you want to do this, you'll have to pass it the value of ServoDataPtr and that will have to be stored locally in the object. This has nothing to do with cogs. It has to do with objects and their scope rules.
Great, that clears up alot. Thank you so much. My next question is, why couldn't I make ServoDataPtr a global variable so that I wouldn't have to pass it? I'm sorry if this is a stupid question, but I think it would clear up a bunch. Again thanks.
Craig
