Questions about making a propeller based product
My dad had an idea for a add-on product to replace a manual set of controls on a popular boating item.· The logic that it would do would be pretty simple, and could almost be done with a basic stamp which I have used before, but one thing it would need is a timer, and my programming skills are better than my electronics, and would rather have something on-chip like the prop does.
Also, I would like to someday do this kind of development work as a side business when I retire.· Lord knows I wouldn't be able to quit my job now and do this and make a living, but it would be fun to do for some side income (if any!), and its better to use a more versatile chip like the propeller, even if I have to learn a new language.
I also want a chip fast enough to read quadrature encoders.· I had a stamp and it wasn't fast enough to capture the transitions.
Anyway, here's my question.· I don't mind spending money up front for the development boards etc, but when a product is made, are there decent alternatives to get an integrated board that has the prop with the necessary hardware mass produced (say 100 at a time or more) that are more cost effective than are sold here?·· The one-off's I see here are good for a single project, but for the prop chip plus a board it would be in the $50-60 range which would be a large chunk of the margin.
I've seem some interesting products that Bean has made which are intriguing, especially the USB device.
If my quesiton requires more specifics, I apologize in advance, but would be happy to try to give more if needed.
Thanks.
Jeff
Thanks.
Jeff
Designing your own PCB is really the only practical way to mass produce moderate quantities (100's) of a system. There are companies that will assemble the boards for you. Again, the Propeller specific parts really only include the processor, crystal, EEPROM, a couple of passive components, and a header for programming.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
On a cost savings basis, I would probably be better off seeing if someone on the SX··board (or other pic sites) wanted to design/build this thing for me (for a fee of course).· The logic of this thing would be soooooo simple.· Almost laughable to use an MCU.
Thanks.
Jeff
Leon
Post Edited (Leon) : 6/22/2008 12:46:34 PM GMT
Newbie question here:· Even though I have programmed a stamp before, I've never done the final step of loading the code into the stamp and have it run on its own by just being powered up.· I assume its a simple process with the prop/stamp?
Thanks.
Jeff
Leon
My question is: What on a boat needs a quadrature encoder. Aren't
they enough trouble as it is [noparse]:)[/noparse]
"Sailing is the fine art of becoming ill while going slowly nowhere at great expense"
Making your own circuit board is quite simple and cost less that paying for some one elses most of the time. I designed a board and had 4 made for less that $100.00. Sure that is a little costly but for 4 new prototypes its not that bad.
here is a picture
The Protoboard is the closest to what you're asking. The only thing missing is the headers which you can easily solder in place. You can add the components needed for as many ADC inputs as you need. They require two resistors and two capacitors mounted as close as possible to the processor chip. Realistically, you could probably get 4 to 8 mounted on the Protoboard.
There is a variety of boards available for the Propeller, usually developed by someone for their own projects. Unless your needs are much the same, the particular design isn't quite what you need and you have to make modifications or build your own. ADC inputs particularly are a problem for prototype boards because the additional parts have to be close to the processor chip, so the design has to commit I/O pins to that function or at least plan for it.
Leon
Leon
Have you looked at the datasheet for the Propeller? If you're not using all the cogs or if you're using them intermittently, the power consumption drops a bunch. For many applications, you don't need to run the processor clock at 80MHz and the power consumption drops rapidly as the clock slows down. With an 80MHz clock, you're talking about an instruction per cog per 50ns. If most of your I/O is serial communications and encoders, you can easily slow the clock down significantly and markedly reduce the power consumption. Jeff Martin's encoder driver has formulas in the comments for clock cycles vs # encoders and max. RPM. At 32MHz, you can have 16 encoders at 1048 RPM. The current draw per cog is about 1/2 at 32MHz vs. 80MHz. With a 32MHz clock, the FullDuplexSerial driver still should be able to handle 115KBaud.
Post Edited (Mike Green) : 6/22/2008 4:28:49 PM GMT
Leon
Power consumption is unlikely to be a problem I'm guessing but again we don't really know the application.
Graham
Leon
Thanks.
If this idea of his has any legs, it would be more profitable to use the sx chips.·
Thanks.
