Amp-controlled battery charger
I am trying to figure out a way to charge a battery at a certain amperage. It doesn't have to be perfect, and I don't want it to be digital. I'm looking for a better replacement than just a 10/12-ohm resistor between incoming power and battery terminal. I'm thinking some type of voltage divider between incoming power and battery terminal hooked to a transistor.
The idea is, with a resistor, as the voltage of the battery increases, the charging amperage decreases. I want the setup to at least be a little less linear, and try to keep the amperage up (as best we can) as the battery charges (of course until it gets close to incoming voltage).
Any one have any ideas, or existing solutions?
Post Edited (Bobb Fwed) : 6/19/2008 8:45:49 PM GMT
bV = battery voltage
By monitoring the "voltage" across your resistor, you can determine the amount of current your battery is being charged at. Now as you have indicated, as the battery charges, the voltage observed across the resistor will decrease as well as the charging current, but if you increase the voltage supply as the battery charges, then the current will be constant.
You also should be very aware of the battery chemistry in which you are charging, so that you don't exceed the recommended voltage per cell.· Doing so will cause out gassing, and eventually lead to a useless battery.· Not to mention explosive gases that will be released.
To properly do this, you need to figure the Maximum Charge current that you want, as well as the Maximum Voltage you will be charging at.· Based on that, you can select an appropriate charger power supply that will do the job.· Next finding a transistor bipolar or mosfet (<-preferred) that will be able to handle your current demands.· Usually the rule of thumb is to at least double your current requirement when selecting a transistor.· Lastly, make sure that your resistor can properly dissipate the heat at whatever current you have determined.
Beau Schwabe
IC Layout Engineer
····IC = {Vin – 0.6 – (Vin · R3) / (R2 + R3)} / R1
Since the transistor is operating in its linear region, it may need a heatsink.
Note: In both circuits, under the specified conditions, the charge current does not diminish once the battery is fully-charged. This may not be desireable!
Post Edited (Phil Pilgrim (PhiPi)) : 6/19/2008 9:49:35 PM GMT
