Untentional self-modifying code or tropming on memory?
Outline of code (complete project is attached)
John Abshier
edit:· in summarizing the code I left out the incrase in wait.
The printed value of CYCLE_TIME in the repeat loop is 0 then 45 then 45. The waitcnt waits about a minute. If I comment out the cognew statement in Init, the value of CYCLE_TIME is 480000000, the correct value, and the repeat loop takes 5 seconds a requested. escapeStack is set to 400. If I hardcode the value of CYCLE_TIME with an assignment statement, I get the same results. I don't know how to proceed. The text file attachment are the results of several runs.
Post Edited (John Abshier) : 6/14/2008 2:01:29 PM GMT
John Abshier
CON _clkmode = xtal1 + pll16x _xinfreq = 6_000_000 VAR long escapeStack[noparse][[/noparse]400], attackStack[noparse][[/noparse]40], pursueStack[noparse][[/noparse]40], driveStack[noparse][[/noparse]40], telemetryStack[noparse][[/noparse]40] long wantControl[noparse][[/noparse]NUM_BEHAVIORS], speed[noparse][[/noparse]NUM_BEHAVIORS], turnRate[noparse][[/noparse]NUM_BEHAVIORS] long CYCLE_TIME, wait, startWait long leftmotor, rightmotor Pub Main | i CYCLE_TIME := clkfreq * 5 Init wait := cnt repeat wait += CYCLE_TIME sio.dec(CYCLE_TIME) waitcnt (wait) PRI Init | cog sumo.Init SumoBot.Init sio.Start(31,30, 0, 115200) cognew(Esc(@wantControl), @escapeStack) ' need to check if free
"long CYCLE_TIME" the first declaration or putting a "long dummy[noparse][[/noparse]1000]" before it should
hopefully prove that.
You're going to have to start putting debug checks in your Esc() routines and everything
that calls. You can pass the address of CYCLE_TIME into Esc() and then check it is what
you expect and give some indication or halt the code when wrong. Move the check around
and you'll find two points between which CYCLE_TIME gets corrupted, then it's a case of
narrowing it down to find exactly where, then working out what's causing it.
New debug.spin file is attached.· There are no changes to other files in the previously attached archive.
John Abshier
on. Probably best to get on with that debugging and find out where it's happening or you most likely
will get bitten later. Besides, if something is writing out of bounds, it's not writing in bounds which is
another way in which your code isn't doing what you want it to.
Thanks hippy. By the way, are you the same hippy that is on the PICAXE forums?
John Abshier
