Electric Bolt Locks
Hi all,
Anybody knows where to buy a low power (6v or less) electric bolt lock ( usually geared motor and bolt)
without the electronics circuitry?
This would be used for wooden doors.
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
- Stephen
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
Thanks for the links, but those bolts all require 12v and many milliamps.
What I need is something that can run on batteries, like those in safe boxes.
www.fd.com.my
www.mercedes.com.my
Here in Taiwan, my building has a front door that opens with a regular keyed cylinder lock from the outside, but has two options on the inside.
Either you push an apparently mechanical button on the body of the lock to leave the building.
Or,
there is a solenoid driven mechanism that connects to a remote button within the intercom on each floor of the building [noparse][[/noparse]we have 5 floors].
I wish I could provide a picture, but I've no idea where to get one. Nonetheless, it appears to be something like 12volts and in 10 years, we have only had to replace it once in the past few months. That is with 20 occupants and visitors running in and out. The unit is surface mounted on the doors interior and seems to stand up to rain and other kinds of abuse quite well.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
