Full Duplex Serial w/ Hardware flow control (rts/cts)
Has anyone modified the current fullduplex serial to allow for hardware handshaking before I hack it up? I know I am going to butcher it because I am not all that good (read horrible) at Pasm.
Thanks!
Thanks!
Good luck. I'm anxious to see you succeed. I'm trying to get the prop to communicate with the Memory Stick Datalogger (#27937). So far with no luck. Please post your results.
Duane Degn
CTS is tested and working. I havn't tested RTS yet
Thanks for link. I looked at the older version of this program yesterday. I'll try the new program "pcFullDuplexSerial4FC" today. I hope the untested RTS works.
Duane Degn
Post Edited (Duane Degn) : 6/16/2008 9:39:16 PM GMT
16 ports without hand shaking would need 32 I/O's
assuming only an EEPROM, and a serial programming port, 15 non-handshaked serial ports are possible, with four instances of the quad driver.
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
Las - Large model assembler Largos - upcoming nano operating system
