Bad board?
I just received my starter kit, but I think the board is bad. I just want to verify that I didn't miss something obvious.
I suspect that the FTDI USB serial converter is bad. The green power LED comes on, the several yellow LEDs light sequentially back and forth, I get vga output, the red and blue LEDs by the usb connector flash briefly.
The prop tool did not find the device after I ran the CD install. I downloaded the newer version Prop Tool 1.1 and restarted. The board was detected. After a few actions (loading example programs), the tool reported the board was not detected. At first, rebooting the pc and power cycling the board allowed detection, now it does not. I see the messages:
Cannot Start Hardware
There was a problem installing this hardware
This device cannot start (code 10)
Originally the USB serial converter was detected on COM3, after the errors the message would say something like
"Device on COM3 was not detected. Would you like to eliminate COM3 from detection in the future?"
I do not think I selected yes, nonetheless I do not get COM3 in my list of ports anymore.
I swapped the USB cable to each availible port, my usb mouse and keyboard have no problems and work in all the ports.
Is there anything I should try before RMA?
Thanks!
Thanks!
Try downloading the FTDI driver either from Parallax's website or from FTDI's website and reinstalling it.
The behavior you describe for the board sounds correct (green LED on, red & blue LEDs flash briefly).
A bad board isn't likely since we test all of them, but I suppose it is possible. If you don't have any better luck by Monday morning please call us and ask for the tech support guys. If they can't get it working we'll replace it right away.
I am unable to reinstall the driver FTDI-usb-vcp-driversR9052151 by itself, this is making me thing the the FTDI chip is no longer talking.
Also, the times the board worked, the red and blue LEDS flashed several times, like it was transfering data, now they flash only once (like 1 ms).
Try using Windows to uninstall the FTDI USB driver, then reinstall it from scratch.
The CD has an older version of the driver (along with an older version of the Propeller Tool).
Again, the behavior you're describing sure is typical of a USB driver problem, not a hardware problem.
uninstalled Proptool1.1 and went back to the CD
I installed the FTDI drivers first. Then I installed Proptool 1.05.8
The install asked to install/update the usb driver, I selected yes.
The confirmation window said the FTDI driver had installed successfully.
I powered up the board, and connected the usb cable. I get the
"USB device not recognized" message.
The hardware wizard says "Found new hardware USB serial converter"
A window opens saying "Cannot start this hardware"
"There was a problem installing this hardware"
"USB serial converter
"This device cannot start (code 10)"
Now USB serial converter is displayed iin device manager under Universal Serial controlers (NOT under Ports) as USB serial Converter
and is flagged with a exclaimation point as a problem device.
Is there an INI file I need to delete when I unistall? I get the impression that the driver is blocked by some eariler failed attempt?
I guess I'll play with my BS2 until Monday.
Thanks for your help
I've got a couple items that won't run on front (case) ports, that work fine on
rear (motherboard) ports, etc. Try it.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
every thing worked well.
The 7V power supply worked well with the BS2 setup but not with the prop starter kit.
Siri
I also tried installing on a different machine, a Compaq EVO-D5S using PropTool v1.1 (bypassing the CD install of V1.05.xx). On this machine, the install ends with an error message :
"OS_Detect.exe
The application failed to start becasue the application configuration is incorrect. Reinstalling the application may fix the problem."
Reinstalling; removing and reinstalling; rebooting, removing, rebooting, reinstalling; swearing, scratching my head, asking my five year old; all had the same result.
However PropToolv1.1 comes up. Let's see how it works....
Plugging in my questionable board gives the message:
Found FT232 (something or other)
Then the SYSTEM CRASHED: "Windows Shut down to prevent damage to your system" with that pretty dark blue screen.
I'll post again after it restarts.
The message from the task tray says:
USB Device not recognized.
One of the devices has malfunctioned
Summary: this board does not work on two separate PC's
One installed from the CD and then upgraded to the PropTool V1.1 that I downloaded;
and the other starting with the PropToolv1.1
I'm begining to suspect that an RMA number is in my future.
I RMA's the first board, and got a second (Thanks Ken!)
Plugged it in, the same damn thing happened as with the first one: after downloading one spin program, the usb serial stopped working with the messages listed above, disconnected prop and power cycled PC. Did this several times to see if changing to PS/2 mouse etc has any affect, it did not.
During troubleshooting, a Windows Update asked to download files, I permitted this, and it asked to reboot, I permitted this.
Now the Prop Demo board works fine, the issue does not occur, I cannot reproduce the issue anymore. I do not recall any mention of USB issues in the Windows Update, but I can't think of anything else that could account for the change. At least I'm up and running. Thanks for your help, guys!
