Assign 6 inputs in one variable — Parallax Forums
DeividDeivid Posts: 2
edited 2008-06-17 04:12 in BASIC Stamp
Hi everybody
I can't figure out how to assign 6 ports in one variable.
I've a basic stamp 2 with P3-P4-P5-P6-P7-P8 as inputs.
My idea is to get a event number from this ports, for example if:
P3=1
P4=0
P5=1
P6=1
P7=0
P8=1
event = %101101 = 45
So knowing the value of event, can i work with this code:
rutine1:
IF (event < 1) THEN do_something
event=event - 1
HIGH LED 'just an example
PAUSE 250
LOW LED
GOTO rutine1
do_something:
some code ' here jump when the led has timed on/off "event value" times
Deivid
    edited 2008-06-15 00:50
    You can assign 4, 8 or 16 pin states to a variable of the correct size. Look in the editor help file under Memory and Variables.
    - Stephen
    edited 2008-06-15 04:20
    Deivid,
    You could say something like...
    event = INS
    ...To capture the entire 16-Bit port.· Then you could mask the·pins you are interested in with something like this...
    event = event & %0000000111111000
    ...At this point you could use the data just as it is, or you can shift it right by 3 to justify the data with something like this...
    event = event >> 3
    Beau Schwabe
    IC Layout Engineer
  • DeividDeivid Posts: 2
    Thanks Beau Schwabe for your suggestion, I had to change pin configuration, to use only one byte, I looked the editor help file under Memory and Variables as Franklin said, and l came up with this code:
    DIRL = %01000000
    A         CON   20
    porta    VAR  Word
    event     VAR  porta.LOWBYTE
    Get_Event:
      compare = %00111111
      event = evento & compare
    IF event = 0 THEN Main
    Mode_1:
      event = event - 1
      PULSOUT A,3
      IF (event > 1) THEN Mode_1
      GOSUB Mode_2
    if event=5 (%00000101), I got 4 pulses in A
    should this works?
    PS: Right now I haven't a Basic Stamp, this is for a project in classroom.
    Deivid
