12V High Side Switch
Does anyone know of a switch that I can put on the high side of a load (the low side is not accessible) that I can·operate with an SX?· The switch will be normally closed and needs to be opened only intermittently for a short·time (2-3 seconds).· The current could be in excess of 15 amps, 20 amps max.
I looked at Crydom and they only have one relay that looks like it will work but it's almost $30.· And besides, I would really prefer to have this switch be small and mounted on a PCB with the SX.
I tried a logic level mosfet (FDP7030BL) but it doesn't seem to work.
Any ideas?
Any ideas?
Post Edited (Mike Green) : 6/13/2008 6:00:13 AM GMT
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
Chris I.
