Cheapest way for simple wireless serial
I am looking for a cheap way to have to PCs connected through serial wireless.
Here are my specifications:
Mandatory features:
-Baudrate = 115.200
-Range= 100 meters (open space without walls)
-Would support only TX,RX and GND
-Inmune to noise in a high noise environment
-Must not produce interferences
-No software·should be necessary to operate. It must work trasparently.
Optional features, although highly desirable:
-USB powered.
-Selectable communication channels. With at least 2 channels.
-Would support all serial basic control signals (CTS, DSR, etc)
Other Optional features:
- Optionally, battery operated. That is to say, should·support power supply and optionally battery.
I have found several solutions that match these specifications but are pretty expensive, between $80 and $200 each board. So I have been thinking on making my own wireless serial solution. Of course I am writing here because I would like to hear opinions·about possible solutions you may have in mind. The cheapest, the better !!
Post Edited (peterz) : 6/4/2008 6:32:10 PM GMT
Mandatory features:
-Baudrate = 115.200
-USB powered.
Building it yourself will be a great learning experience, but you will definitely be unable to meet all of your spec for less than your budget.
Will the knowledge gained and time value expended in designing and building your own be worth more than buying a working product and gettting on with the overall project? Or, can you modify the spec so you can work with the cheaper radios?
Cheers,
Tom Sisk
http://www.siskconsult.com
115,200kBaud
Indoor range: 100m
Outdoor range 1 mile
2.4GHz Frequency range
$32 each
http://www.digi.com/products/wireless/point-multipoint/xbee-pro-series1-module.jsp
The regular XBee is $19 each
Indoor range: 30m
Outdoor range: 100m
http://www.digi.com/products/wireless/point-multipoint/xbee-series1-module.jsp
If you are looking for a final PC-based solution that is USB, I have some boards designed for interfacing to a PC with USB to a wireless signal.· This does (obviously) require software to run.
I may be willing to sell the full product to you, I would just need to figure out pricing...
Post Edited (Steel) : 6/5/2008 6:32:09 PM GMT
http://geocities.com/SiliconValley/Orchard/6633/rfremote.html
http://www.rentron.com/Stamp_RF.htm
Any other links?
The other cool thing about the Xbee's is that they have built-in data checking plus automatic resend, so it guarantees data delivery.
