Best way to run Propeller on batteries
william chan
Hi,
I need to run the propeller off 4 x AA Alkaline batteries.
I want to put the Propeller to sleep when it is idle to save on the batteries.
I also can't afford to waste the quiescent current of a 3.3v regulator when the propeller is asleep.
I hope to get the total board sleep current to less than 100uA.
What is the best way to do this?
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
I bought some LTC1308 single cell DC-DC converter chips recently, but haven't had the opportunity to try them out yet...
If you have an external event that would turn "ON" the Propeller, then see my reply to this thread...
Reference Thread: http://forums.parallax.com/showthread.php?p=730612
Schematic: http://forums.parallax.com/attachment.php?attachmentid=54043
..This circuit will keep you in low power standby mode somewhere in the nano amps.· Instead of the 5V regulator shown in the schematic, remove the 5V regulator and run the power output from the SCR (made of discrete transistors) directly to the 3.3V regulator instead.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 6/10/2008 3:27:48 PM GMT
If you use a modern 4 switch synchronous buck boost regulator you can achieve > 92% efficiency, while the older switching regulators get you 80 - 85% efficiency.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 6/10/2008 11:26:52 PM GMT
(Of course he could still use a step up but I don't know what the current requirements are and I am not good at designing stuff from scratch)
Which op-amp part number would you recommend? Which zener diode can reference 3.3v at at few microamps?
Why commercial 3-pin linear regulators cannot be based on such a voltage follower design to reduce the q current to uA range?
Rayman,
I searched LTC1308 at octopart.com and farnell but both sites does not know this IC.
What would be the q current for this part?
Beau,
Your SCR circuit is beautiful, but unfortunately sometimes I may need to go into low power mode instead of totally off.
The LM1117 3.3v regulator eats 4mA q current, so it is a problem for the batteries.
Which configuration use less current, 1Mhz crystal with 4x PLL or 4Mhz crystal with 1x PLL?
David,
You are right, I also need the 6v for running a stepper or servo motor.
Do you think the torque of the Parallax stepper motor would be too weak if run from 6v?
Thanks everyone, but the problem is still elusive.
www.fd.com.my
www.mercedes.com.my
Post Edited (william chan) : 6/11/2008 1:10:15 AM GMT
These newer NiMH's can be identified simply because they come precharged! Showing a level of confidence [noparse]:)[/noparse]
I think Sanyo were first off the blocks. en.wikipedia.org/wiki/Low_self-discharge_NiMH_battery
Evan
The LP2950 is a 3 pin linear regulator with only 75uA quiesent current.
The LP2951 has also a Shutdown Input and an Undervoltage output.
Both are available at Digikey and cheap!
Andy
I agree with Phil, the CR123A lithium primary cells are probably the best choice to directly power the Propeller with.· Like Paul was suggesting, you should probably·consider multiple cells in a parallel and/or series and parallel configuration where you could tap off 3 v for the Propeller and 9 v or 12 v for the steppers for the best performance as that will give you the different voltages you need and will afford you larger mAh.
I imagine that if your batteries are too drained to run the steppers, it doesn't matter if you still have enough power for the Propeller... but in case not, you could use something like the LT1307, it's q current is 50 uA, uses a boost mode for low demand situations and can take an input range of 1 to 5 vdc.· There's a number of other Linear Technologies regulators in the same class, but here's a page for this one:
http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1042,C1035,P1522
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
Post Edited (Jeff Martin (Parallax)) : 6/11/2008 3:52:16 AM GMT
I ran a quick search on TI.com and found a voltage regulator with 33uA quiescent current. They have some free SOIC-8 samples so you can order a few and try them out with your setup. I'm not sure if this really is the best way to go since you've had numerous people weigh in with other suggestions, but here's a link.
http://focus.ti.com/docs/prod/folders/print/tps76615.html
Have a look at the MAX1705.
♦ Up to 96% Efficiency
♦ 1.1VIN Guaranteed Startup
♦ Up to 850mA Output (MAX1705)
♦ Step-Up Output (2.5V to 5.5V Adjustable)
♦ Linear Regulator (1.25V to 5.0V Adjustable)
♦ 1μA Shutdown Mode
♦ Voltage Monitor
♦ Pushbutton On/Off Control
I have included here a sample circuit.
Regards
Azlan
These chips are amazing, especially the TI tps76615 with only 33uA q current!
But I think I will settle for the LP2950 b'cos they are available from Farnell and its simpler with 3 pins.
Thanks everyone.
Azlan,
I am still afraid to go with switching regulators.....
How's your Propeller project coming along?
www.fd.com.my
www.mercedes.com.my
Project going well, design finished now waiting for prototype PCB's to come back.
I am going to need a few P8X32A-Q44's for the prototypes, I will give you a call later.
In the meantime why don't you like switching regulators?
Regards
Azlan
Some calculations are in order me thinks, on how much energy will be needed for each move and also how often are moves performed and finally how long do you want between battery changes.
Evan
datasheet: http://focus.ti.com/lit/ds/symlink/tps63000.pdf
report on·it's intended use of extending·Li-ion life: http://focus.ti.com/lit/an/slyt256/slyt256.pdf Looks like this could be the chip to use for me; the 63001 is 3.3v version.
Post Edited (Fred Hawkins) : 6/14/2008 3:07:32 PM GMT
From the data sheet:
"The LT®1529/LT1529-3.3/LT1529-5 are 3A low dropout
regulators with micropower quiescent current and shutdown.
The devices are capable of supplying 3A of output
current with a dropout voltage of 0.6V. Designed for use
in battery-powered systems, the low quiescent current,
50μA operating and 16μA in shutdown, make them an
ideal choice."
