BS2pe: where is the excess memory for data logging?!
Hi,
AN OTHER PROBLEM !!
I have ordered BS2pe for Data Logging and a bigger area for programming but when I use Memory Map window to see how much space I have, the memory space is equal to my old BS2 (EEPROM = 7F0F bytes). how it can be? based on my (little!) knowledge, I should have 16 times more memory now. but i can't find it.
please help me with that.
thank you guys,
Ali
AN OTHER PROBLEM !!
thank you guys,
Ali
To access that additional program space, you will need to read up on the RUN command in the manual. Plan to divide your program up into pieces.
All 16 slots can hold data, for example, for your data logging. The STORE command is used to point at the slot you want to use for data logging, using the WRITE and READ commands to address bytes 0 to 2047 within each slot. For example, the following program makes an exact copy of the contents of slot 0 into slot 15:
char var byte FOR index=0 to 2047 STORE 0 READ index, char STORE 15 WRITE index, char NEXT STORE 0 ' point to slot 0Also read up on the scratchpad RAM, with is common to all of the slots, and is accessed with GET and PUT.
To use additional slots for a project, you create a new program and then put a special directive in the slot 0 program:
' {$STAMP BS2pe, myslot1program.bpe, ...} with entries to associate up to 7 slot programs with the project.
Tracy Allen
www.emesystems.com
thank you for your very useful comments.
your great!
