PWM Battery charger
Ok. Here is my first major project. I'm building a charge controller for RE (Renewable Energy) systems. I'm incorporating as much flexibility as as I can into the design.
I'm incorporating the propeller chip as my base mainly because I really want to sink my teeth into this chip. The first phase of this project is to get the controller to charge 2 lead acid batteries (Jameco #318924, 12v 3.2ah) in a series. At first I'll use a 24vdc power supply for my first testing phase. I'll switch to a PV panel(s) or a wind turbine after that.
A couple Notes:
1. I'm utilizing the CTRA and CTRB control registers for PWM control.
2. I am considering switching to a 12 bit ADC (MAX1270) to handle NiMH as well as lead acid.
3. I want to include a LCD display.
4. Additional monitoring for multiple power sources (Some RE installations have solar, wind, and/or hydro sources).
5. I want to tie it to a computer to gather data and remote monitoring.
That's a good start for now.
I want to know what you all think so please have a look at my schmatic and let me know.
Thanks in advance.
A couple Notes:
I want to know what you all think so please have a look at my schmatic and let me know.Thanks in advance.
if your project is a one off for home use, and the purpose is to learn propeller- then fine.
If its for a commercial application, then there are far better and cheaper solutions.
a pic16 would eat the task, and cost far less.
there are loads of application notes on charging batteries.
http://webdc.transim.com/microchip/
microchip app note AN1015 "Programmable Lead Acid Battery Charger" may help
an 80MHz, 8 processor chip is not required to control the charge to a battery.
choose the appropriate solution for the problem is always a good maxim.
You have your 3.3V regulator connected to one Vdd pin on the Prop and the 5V regulator connected to the other Vdd pin. NOT a good idea! Connect your 3.3V regulator to both Vdd pins on the Prop!
Looks like you're powering your ADC with +5V and the Prop with +3.3V. You should have resistors in your data lines between the ADC and the Prop to avoid damage to the Prop due to the difference in voltage levels. 220 ohm is the recommended value.
Good luck and happy charging!
Mike, I think the Prop is perfect for this! I am working on a controller for my solar hot tub. While it certainly can be done with other MCU's and perhaps for slightly less cost, the Prop just makes everything so dang easy...
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
The full-wave bridge is a good idea.· Allows you to connect it to any source - AC or DC, without careful attention to the polarity.
Scott
Ray
A few things I did note in addition to the above comments (in order of severity):
- No Fuses – anywhere…· This is dangerous. Period.
- There is no voltage control for the input to the battery (your battery can explode due to over-charge)
- There is no temperature monitoring on the battery (your battery can explode due to over-charge)
- No current detection (for PWM control input) – without this, you can’t control the battery’s charge at all… aside from only connecting the solar array to the battery then the voltage exactly matches the charge voltage set-point (this would probably happen twice a day for about three minutes
- You are using a relay for PWM (I presume for high speed switching…[noparse];)[/noparse] – this will wear out after a million or ten switches. Think about this - if you are switching at 3kHz, this would take about 30-300 minutes at full relay contact load… (not reliable at all…[noparse];)[/noparse]
I assume you are planning to use a permanent-magnet wind/hydro generator (output voltage varies based on wind speed or water flow), which matches roughly the characteristics of a solar array.· If not (as in, you intend to use an automotive rectified alternator), you need to build-in a voltage regulator for that as well…·
I’ve attached a few PDFs for you to read through as well – the big one is split up into three files (because of the forum’s file-size limit).· This is a compilation of the best battery/battery-charger information I’ve ever found.
I would recommend that you do some research on MPP (Maximum Power Point) solar chargers, if you are even going to do a smart solar charger (not just a few transistors…[noparse];)[/noparse].· You will probably also benefit from reading up on multi-stage battery chargers (the big PDF has a ton of good info in it…[noparse];)[/noparse]
A few suggestions:
- Use the Propeller as a battery monitor as well (all that extra processing horse-power should be put to GOOD use…[noparse];)[/noparse] – this will give you an idea of “state of charge” and run-time remaining.· You can use that information internally to the Propeller to manage things like load dumping etc. to manage the available power.
- Use power MOSFETs instead of relays for high-speed switching (they will last a lot longer)
- Look into switching supplies (specifically "4-switch buck-boost"), you can·emulate this function·with the·Propeller-based·charger to squeeze power out of your solar cells even when they are severely shaded (or the wind is just barely blowing, or the stream has only a trickle…[noparse];)[/noparse], or if the solar array, wind, or water turbine are producing a voltage way over your battery charge voltage set-point.
- Don’t use a bridge rectifier in your final design – you don’t want to have anything in the “ground” path at all.· A simple diode on the + side will suffice to protect against reverse polarity or solar array power leeching (at night).· Remember every diode junction you go through is one more voltage drop and a loss in efficiency…
- Especially if you plan on mounting this to a house or something outside – put a transient voltage suppression (TVS) device on your + input to the circuit from the generation devices to protect the Propeller and the attached loads from things like lightning or surges.
One thing I’ve joked about in all semi-pro solar installations – is the diversion load.· If you’re going to put in a diversion load – make it do something useful…·
In a home, have it heat water or turn a circulating fan (things that need to happen anyway).
In a car, have it keep the engine warm or the interior cool.
-Tim
Post Edited (GreyBox Tim) : 6/4/2008 10:07:14 PM GMT
The three part "Mobile POwer FAQ" is telling me it is corrupted when I try to open it. Is there anyway I could get you to email me the entire thing? I'd really like to read it. My address is jpeakall AT madlabs DOT info. It would be much appreciated.
I just bought an off grid property, so I'm learning all I can.
Thanks!
mikestefoy:
I couldn't agree with you more. I kind of hinted that there are other integrated applications that I will be add later to this project over all. I am taking small bites, for now, and will be adding more later. Thank you for your input.
Ken Peterson
As the said on the old SCTV show "...that blowed up real good!"
That is where I ment to put it. Ughhhh Here again really tired, late night.
Jonathan
The power source on the schmatic was general, at the time, to help me get through the initial design. I have corrected that on my current incarnation of the schmatic which I'll post in the next couple of days.
Rsadeika
As I said above, I'll be intergating others thing into the design at a later date. I don't want to overwhelm myself just yet. LOL
GreyBox Tim
I can't thank you enough for all the great information and pdf's. It will take me some time to pour over all that great information. I really appreciated it.
I was pondering over a way to just that, using the excess power in some creative ways. It will be added as I get the different phases stable and working. Thanks again for all the great info.
Also, the multi-part "Mobile Power FAQ (Victron Energy) and Battery FAQ (Web).zip" was corupted for me as well. Would you please send a copy to my email address as well. gvg451 AT yahoo DOT com.
Thank again to everyone for the input and sharing of ideas and information. It's good to know that people still wish to help each other out in this crazy world of ours.
Garth
On the zip file thing - I noticed something that Windows is screwing up when it saves the file - it renames the first file as a .zip file (instead of leaving it as a .001 file). This causes it to be seen as corrupted.
My email accounts have a 1MB file size limit so I can't email it directly to people. If you're still having trouble opening it - use 7zip, which is an open source free software (much better than the Windows internal compressed folders tool or WinZip or WinRAR). This can be found at www.7-zip.org (use the stable 4.57 version).
-Tim
Can't open it with 7-zip either. I poked around and found Victron Energey, but couldn't find the FAQ. Sorry to bother you, but if you have a link that leads to the document, that would be great. It's all your fault we are so interested, you said it's the best you've seen. :0
copy /b "Mobile_Power_FAQ_(Victron_Energy)_and_Battery_FAQ_(Web).zip.001
" + "Mobile_Power_FAQ_(Victron_Energy)_and_Battery_FAQ_(Web).zip.002" + "Mobile_
Power_FAQ_(Victron_Energy)_and_Battery_FAQ_(Web).zip.003" "Mobile_Power_FAQ_(Vic
Then you have a zip file that opens.
-Tim
Edit: I have confirmed that Timmoore's meathod also works well. -T
Post Edited (GreyBox Tim) : 6/5/2008 9:32:07 PM GMT
[noparse][[/noparse]code}copy /b "Mobile_Power_FAQ_(Victron_Energy)_and_Battery_FAQ_(Web).zip.001
tron_Energy)_and_Battery_FAQ_(Web).zip[noparse][[/noparse]/code]
Worked for me. Just so you know.
Garth
Is the above using 7-zip, or just from the winblows command line?
Jeremie, the forum admin, has gratiously posted the PDF to the Parallax FTP site at:
ftp://ftp.parallax.com/Mobile Power FAQ (Victron Energy) and Battery FAQ (Web).pdf
A big hats off to Jeremie!!
-Tim
Jonathan
