Fluffy2 Programmer
My computer doesn't have the serial port.
I want to have the same exercising as it done by using improvement version PIC16F648
A of "Fluffy2".
Is this possible?
I note the content of the CONFIG register the setting of an analog port with Deholt.
What respect do I only have to note besides?
Please give detailed attention when it is possible to do.
Change point with "Schematic" of "Fluffy2"
I want to control the output with an external element detecting the "13.2v" making and the voltage by using "RA3" and "RB3" (PWM) with the charge pump of the capacitor and the diode.
In this case, it is possible to use it for "RA4" to change by not using "RA3" and reversing "RB3" (PWM) with an external transistor.
If PWM is used, it is not necessary to control the reason with software.
(The output is controlled with an external circuit with PWM constantly output. )
Additionally, RB4 is made RB1 for serial communications, and RA2 is
allotted to RB2.
"VDD" The control applies "RA2" to the change of "RB1".
Speed switch "RB7" is changed in "RB5".
Besides, "RA4" doesn't have signs used now. It seems to have used it in "Fluffy".
I want to control serial communications by passing "FT232RL" with USB virtual serial
port of WIN2000.
If RB1-RXD and RB2-TXD are used in the hardware mode, a further high-speed
communication can be expected.
An accurate system clock can be supplied by being able to take out internal 12MHz of "CBUS4" of "FT232RL" and connecting it with "RA7-OSC1".
Or, other "Crystal oscillator" can be installed.
It is almost incompetent to bring software together though I am good at the summary of hardware and the entire idea.
A possible person must help me.
nonnno
Post Edited By Moderator (Bean (Hitt Consulting)) : 6/5/2008 2:10:45 AM GMT
A of "Fluffy2".
Is this possible?
allotted to RB2.
port of WIN2000.
nonnno
It sounds like you are trying to make an SX-Blitz.
You can purchase this from Parallax for less than $30.
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/ProductID/368/List/1/Default.aspx?SortField=ProductName,ProductName
Bean.
Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
www.iElectronicDesigns.com
Thank you for the answer.
However, if it is not US$200 when buying it in Japan, it is not possible
to buy it.
A changeable mechanism of the frequency of the clock has adhered by the
latest USB version, and it is very good.
It gropes for the method that buys from the United States.
nonnno
