The Professional Development Board mounted in side a double compartment fishing
·Hi all
·I just moved this project from the basic stamp forum,there it was titled, need info on anti-static mat.
·I just glued a cut section of the anti-static mat to the in side of the cover where the PDB will be mounted.
·It takes 24 hours for the glue to cure.
·I'll try to show some pictures later.
·allie
·allie
To make a long story short....another name for the anti-static foam is "conductive" foam. And it does conduct! If the bare backside of a circuit board is touching it, you will have problems.
Lesson learned that day.
I hope the "anti-static mat" you are referring to is a different type of material.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
·The cpu anti-static mat which I'm using isn't showing any resistance at all with an ohm-meter reading(please check out my post on this, on the basic stamp forum, titled "need info on anti-static mat".
·The PDB which I mounted has rubber mounting pads glued under the circuit board and has a clearance of about·· 1/4 inch from the anti-static mat. I'm not sure if the mat is going to do any good or not, but I can not see it doing any harm. I may as well use it here because It,s not what I though it would be, when I bought it for a work mat. It has a ground strap on it so I,ll use it for this project.
·If the mat is good enough to set a cpu on, it should be all right under the PDB, to keep static charge from building up.
·regards allie
Ted
An interesting idea to be sure. If anyone is interested I can look up the project and post here.
Ted
·There is no part of the circuit boards bottom, near the anti-static mat. There is a 1/4 inch space·from the bottom of the board and the mat. The board is mounted on rubber feet.
·I washed the tackle box with soap and water and it seems to be static free, but I will try the suggestions that you posted above.
·Thanks for advice.
·Allie
·But I needed to mention this. If any one else drills these, do it at your own risk.
· I also used plastic screws which I threaded my self for the fasteners. I didn't want to take a chance of shorting out the PDB with medal screws.
My PDB is newley purchased with a 2007 REV D stamped on it.
allie
Post Edited (allie) : 6/4/2008 12:17:21 AM GMT
