ethernet telnet problems (blocking calls, buffers)
Ok, I have played around with spin for a while and I am now testing ethernet, with the fullduplexserial I could read the whole buffer to get what was sent and checking to see if there was data didnt block anything, it seems it is not the case with the ethernet driver?
let me show you what I have that is the problem
I defined it as ser at first, changed to make it more clear as to what it is
I NEVER get a no data string and it pauses execution once I call that function and does not return until it sees data sent.... What am I doing wrong?
I want it to see if data is ready if so append it to my variable, if not, come back quickly so I can do other things
Once that is working, the method I am using misses data, if I use terminal and send a complete string of 1234567890 my buffer now looks like this 124680
Hope I made myself and my code more clear
Post Edited (SpinHead) : 6/1/2008 8:08:06 PM GMT
Num : "Simple_Numbers"
eth : "api_telnet_serial"
time : "Timing"
serial : "FullDuplex"
serial.start(serRXPin,serTXPin,serBaud)
cog:=eth.start(i_cs,i_sck,i_si,i_so,i_int,xtalout,@eth_mac,@ip_addr)
eth.listen(port)
time.Pause1ms(1000)
repeat 'main
if(StrSize(@myString)<7)
readEthernet
SetString( @myString, @dstString)
//do other stuff here while we wait for more data,
//readEthernet should return quickly if there is or is not data <-- this is the problem, readethernet hangs until
// it actually gets data, instead of seeing of any is ready
else
//we have data, verify it is valid and do stuff,
// then reset mystring & dststring to 0 or just reset to 0 if data is not valid
PUB readEthernet
[color=#990000]
if eth.rxcheck
ch:=eth.rx ' get char //gets stuck here I think
[/color]
if(ch>38 AND ch<127)
AppendChar( @dstString, ch )
eth.str(string("NEW CHAR:[noparse][[/noparse]"))//diagnostic stuff temporarily
eth.tx( ch) //
eth.str(string("] - ")) //
eth.str(@dstString) //
eth.str(string(13,10)) //
else
case ch
33 :
SetString( @dstString, String("!"))
eth.str(@dstString)//diagnostic stuff temporarily
else
eth.str(string("NO DATA,",13,10))//diagnostic stuff temporarily
Change the first few lines of your readEthernet method to:
PUB readEthernet if (ch := \eth.rxcheck) > -1 ...rest of your code goes here...Remember that rxcheck will return a character if one exists in the buffer. This means you need to actually store this returned value somewhere, otherwise you loose that character.
I recommend putting a \ in front of all your tcp stack method calls so you can catch any aborts. This is for future functionality (the current beta release doesn't use aborts yet). The next release will have aborts, so 'catching' them now will give you the easiest upgrade path.
Harrison
