New Sparkfun Protoboard looks ideal for use with Prop
Sparkfun just posted a new board that looks good for the prop, they also have matching case and battery.
I am in no way affiliated with Sparkfun but I saw the board and thought that it would be perfect for the prop.
http://www.sparkfun.com/commerce/product_info.php?products_id=8723
It has 3.3v and 5v (step up) with built on ftdi usb to serial converter, battery connector (which can be charged with usb) and space for SMD or TH.
The only thing I'm not to sure about is how well everything would fit on the board.
Anybody see a reason this wouldn't work with the prop.
That saves a lot of trouble trying to solder a Propeller on a Sparkfun board.
James
But for static or wall powered installations, I'd stay with the Parallax board.
Post Edited (Ken Peterson) : 5/30/2008 1:26:08 PM GMT
Graham
It seems there are 0.1" centered holes on this SparkFun protoboard. Are there not enough holes to host a 40pin Propeller chip with a socket? Hmm... The nice thing is you get both 3.3V and 5V native running off the Li-Po battery, it seems, but a lot of parts are involved to get there. If you want 3.3V only plus Li-poly charger in one chip, take a look at the new LTC3558 from www.linear.com. Yes Propeller Protoboards are cheap, but after tossing a couple "cheap" Propeller Protoboards after frying pins and/or processors (this happens some times, even to the best of us), I now exclusively use socketed 40 pin Propellers on home-brew wire-wrap break-out boards that mimic the Propeller Protoboard, in essence. It would be nice to see a Propeller Protoboard from Parallax that has a socketed 40 pin Propeller. Perhaps a one or two dollars higher in cost. But I think this has been requested many times before.
Regards, David
There is a pin header in the dimensional drawings that runs perpendicular to the SMT area, and it shows that the width of the SMT strip spans exactly 6 header pins, which are .1 inch apart. At first I was going to refute that that meant that the gap must be .6 and the .6 DIP Prop should fit it. Unfortunately the distance from the pin holes on one side to the pin holes on the other side must be .7, because we have to count a hole on both sides - I had commited a fencepost error.
I wonder if Sparkfun made the same fencepost mistake in their design?? I can't imagine why you would deliberately build such a nice board which looks so much like it fits .6 wide DIP's, and then go 1 pin past that to render the board useless for those applications.
JMH
