CLIB COG and how to do a CMPEXCH?
I was talking to someone about floating point code for the Prop and the thread in the forum about fast sqrt makes me thinking: we can put a bunch of library code in another COG and use a semaphore mechanism to activate it, e.g. that COG would be executing something like
forever
if (state == LIBCOG_START)
state = LIBCOG_BUSY
<invoke some function>
state = LIBCOG_FINISH
The function will be invoked by some sort of ID, probably a jump table index. "state" and parameters live in HUB RAM of course.
The library function mechanism for these functions then become
if (state == LIBCOG_IDLE)
state = LIBCOG_RESERVE
<write parameters and function code>
state = LIBCOG_START
while (state != LIBCOG_FINISH)
<get result>
state = LIBCOG_IDLE
A problem is implementing the equivalence of CMPEXCH using LOCKs to modify "state." Fro all you Propeller heads, any idea?
So at the cost of using another COG, we get full native speed on these functions.
As for the actual functions
I can think of
- low level FP primitives, pack, unpack, add, sub, etc.
- strcpy/memcpy etc.
- sqrt
I have yet to look at the sin/cos/trig support in the Propeller ROM, but we will probably put the wrapper functions there too.
forever
state = LIBCOG_BUSY
<get result>
state = LIBCOG_IDLE
I can think of
- sqrt
In the case of a library like this that might be used by any of several other cogs, you do need to use LOCKxxx.
Paul Baker
