PROJECT: Miniature Hero
Oldbitcollector (Jeff)
Having played with the Propeller for the last couple years,
I'm finally taking the plunge into some robotics experimentation.
This may be a unrealistic, but I thought I'd take a shot at building
a small hero replica (minus the arm) with a target budget of $150.
So far the project incorporates 2 continuous rotation servos,
a couple of standard servos, a ping sensor and a propeller board.
Still have to run down some minor parts, including a small keypad.
Any ideas on inexpensive fabrication of plastic panels?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
OBC
http://en.wikipedia.org/wiki/Vacuum_forming
http://www.ipfrontline.com/printtemplate.asp?id=453
http://www.build-stuff.com/001book_vacuum_forming.htm
http://distributionbizwiz.wordpress.com/2007/10/02/diy-vacuum-forming-machine/
http://www.warmplastic.com/q_a.html
Do you plan to use differential drive, or stick with Hero's lovingly-flawed tricycle drive? That was the weakest link in Hero's ability to get around.
Robert
Yes, I'm basing the design on Hero 1.
I could really use some pictures and measurements (height, etc) to base my design from.
Most of the pics I'm finding on the internet are fairly poor.
I'm thinking that 1/5 scale will be movable by the servos (I hope, now waiting for more parts)
I'm using some "Erector" parts to form the frame to save on costs.
I'm really shooting for a design which would allow someone with a Propeller
protoboard to replicate the base very inexpensively.
I always wanted my own hero, but the prices were always wayyyy out of my range,
and it's worse now that it's a collectible.
Has anyone got digital copies of the hero features/documentation that would be
willing to share?
OBC
There are also a lot of spare parts (original and reproduction) available to keep the robots going. One of the latest was a USB Interface. It's pretty cool to see Windows XP find a "HERO robot" when you first plug it in.
Robert
Post Edited (RobotWorkshop) : 5/28/2008 4:43:56 PM GMT
It can't possibly be that easy... Looks like a small vacuum former would be pretty
straight forward to replicate. I'm curious what the hole size is in the bottom of the
form plate. I'll add that book to my shopping list!
I'm going for a three wheel design. Two continuous rotation servos and one steering servo.
OBC
Post Edited (Oldbitcollector) : 5/28/2008 8:11:40 PM GMT
A VERY useful modelmaking trick is the use of thin (watery) superglue with baking soda. Alternating layers of these two, you can build a strong, thick, rock-hard fillet, screw boss, hole-filler, bracing rib, almost·anything. Anywhere that needs strengthening can be shored up on the inside this way. You can actually make strong, solid parts out of nothing but superglue and baking soda. In an emergency, I have hand-made GEARS this way to keep a model going. Sort of old-school rapid prototyping.
You forgot to mention that there are a wide variety of polystyrene shapes available. As a model railroader, I have used it in many different construction projects. If you want an idea of the type of scratchbuilding supplies available in styrene, try:
http://www.plastruct.com/Home.html
They have all sorts of plastic rods, tubes, extrusions, I-beams, as well as·thin plastic·sheets with various textures for decoration.
While I'm mentioning materials suppliers, I'd be remiss if I didn't mention K&S metals, available at·most hobby shops: http://www.ksmetals.com ·All sorts of wonderful sheet metals and tubing.
sent the link on vacuforming.. It looks VERY doable! I'll be starting
work on a small forming unit very soon.
Has anyone else here ventured this direction yet?
OBC
