I need help with displaying text using the objects - TV Text and VGA text. — Parallax Forums
SiriSiri Posts: 220
edited 2008-05-27 23:14 in Propeller 1
I know how to display text but what I would like is to display "color text" that is colored letters.Individual letters to be in different colors but not changing the background color.I would like the back ground color to remain "Blue".
I am strictly a spin user and not a ASM user.
Siri
[noparse][[/noparse]Subject Added By Moderator]
Post Edited By Moderator (Chris Savage (Parallax)) : 5/27/2008 3:53:33 PM GMT
  • allanlane5allanlane5 Posts: 3,815
    edited 2008-05-27 15:42
    You can edit your own postings. Click the little "pencil" icon, then change the title on the first posting.
    edited 2008-05-27 15:55
    In TV_Text (and looks like vga_text as well)
    $0C = set color (color follows)
    So your text might look like this..
    text.str(string($C,5,"COLOR TEXT",13))
    OBC
    New to the Propeller?
    Getting started with the Protoboard? - Propeller Cookbook 1.4
    Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
    Got an SD card? - PropDOS
    Need a part? Got spare electronics? - The Electronics Exchange
    Post Edited (Oldbitcollector) : 5/27/2008 4:00:33 PM GMT
  • SiriSiri Posts: 220
    edited 2008-05-27 17:08
    OBC,
    The code you suggested also changes the background color.What I am looking for is to change the color of individual
    letters.
    Siri
    edited 2008-05-27 17:24
    Without modification I'm not sure that driver has that ability.
    (Perhaps someone will jump in)
    You might take a look at the AiGeneric driver which does have
    the ability to change up to 16 colors. The default color for the background is black,
    but I don't see why that couldn't be changed easily.
    propeller.wikispaces.com/AiGeneric
    OBC
  • ColeyColey Posts: 1,129
    edited 2008-05-27 18:20
    Hi Siri,
    If you take a look at the TV_Text object you will find the colour palette definitions.....
                            '       fore   back
                            '       color  color
    palette                 byte    $07,   $0A    '0    white / dark blue
                            byte    $07,   $BB    '1    white / red
                            byte    $9E,   $9B    '2   yellow / brown
                            byte    $04,   $07    '3     grey / white
                            byte    $3D,   $3B    '4     cyan / dark cyan
                            byte    $6B,   $6E    '5    green / gray-green
                            byte    $BB,   $CE    '6      red / pink
                            byte    $3C,   $0A    '7     cyan / blue
    All you need to do is set up another palette in your top level object, like this for example, a modified TV_Text_Demo :-
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    OBJ
      text : "tv_text"
    PUB start | i
      'start term
      text.start(12)
      text.setcolors(@mypalette)
      text.str(string(13,"   TV Text Demo...",13,13,$C,5," OBJ and VAR require only 2.8KB ",$C,1))
      repeat 14
        text.out(" ")
      repeat i from $0E to $FF
        text.out(i)
      text.str(string($C,6,"     Uses internal ROM font     ",$C,2))
      repeat
        text.str(string($A,16,$B,12))
        text.hex(i++, 8)
    DAT
                            '       fore   back
                            '       color  color
    mypalette               byte    $07,   $0A    '0      white / dark blue
                            byte    $9B,   $0A    '1      brown / dark blue
                            byte    $9E,   $0A    '2     yellow / dark blue
                            byte    $04,   $0A    '3       grey / dark blue
                            byte    $3D,   $0A    '4       cyan / dark blue
                            byte    $6B,   $0A    '5      green / dark blue
                            byte    $BB,   $0A    '6        red / dark blue
                            byte    $3B,   $0A    '7  dark cyan / dark blue
    You use the command text.setcolors to change to your own Palette definitions.
    Have fun!
    Best regards,
    PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
    Coley,
    Thank you very much.I will make my own palette as you suggested.
    I was playing witgh the "setcolors" command but had no idea· that I had to make my own palette to get the color combination I really
    wanted.
    Thanks once again.
    Siri
