Wiring up a serial port
Sorry for all these dumb questions lately, but here's a quick one.
While I was designing my board, I for some reason thought my computers had female serial ports, and the serial cable I ordered was a M/F. So, I bought a male serial port and began wiring it up. However, just out of curiosity, I decided to double check my computers, and of course, they're both male.
Now, if I use a null modem adapter (F/F), will there's a problem? I remember reading SOMETHING about using a null modem cord/gender adapter, but I can't for the life of me remember what it was about
Null Modem will flip the Transmit & Receive pins so two pieces of Data Terminal Equipment (DTE) can talk to each other. Used with two computers talking to each other.· DTE is normally a·MALE·connector. DTE is considered to be the ACTIVE end of a connection.
Modems, for example, ·are Data Communications Equipment (DCE). DCE connectors are normally female.· By design, DTE equipment is supposed to talk to DCE equipment with no special wiring.· Serial Cables are therefore normally Male to Female straight-though·cables because the·DCE expects·to receive on the·transmit wire·and transmit on the receive wire·with respect to the DTE end of the connection.
So, to wrap this up... when a DTE (A PC) ·wants to talk to another DTE (A microcontroller)... each device expects to be talking to a DCE device. A NULL MODEM cable emulates a DCE device between the two ends·by crossing over the correct pins.
Male· DTE· RECV on·PIN 2,· XMIT on·PIN 3, GND on PIN 5
Female DCE XMIT·PIN 2, RECV on·PIN 3, GND on PIN 5
There's nothing like a new idea and a warm soldering iron.
You say "my computers" -- so if your second computer is a PC, both ports are "DTE", so you WILL need a 'null-modem' in that case (in fact, a Female-to-Female null-modem cable), to talk from one PC to another PC.
But thanks! I should have this up and running soon [noparse]:D[/noparse]
I have computer with two serial ports available, one male and one female. I need to hook up two Stamps to it and have them send data.
Am I correct that the normal m-f cable will work to the female port on the computer, but I'll need a "null modem" f-f cable rather than a f-f adapter to properly send data to the male port on the computer?
- Stephen
Now I have to figure out how to do it with USBs, then... great, since Java doesn't really support them. Thanks, though, saved me some time.
And I believe the CGA standard uses a female DB-9 connector -- again, useless for RS-232.
So the "standard" PC RS-232 connector is a DB-9 male, wired as "DTE". Yes, if you haven't got one of those, you'll need a USB to RS-232 converter like Keyspan or FTDI. Which will have a DB-9 male on it.
So I guess it's gonna be back to serial comm. and dropping the second Stamp. Java for that won't be easy either, you'd think it wouldn't kill Sun to support hardware decently.
