Call Assembly from Spin - How?
Could some kind person please post an example of how an assembly routine can be called from spin. By this I mean a simple call with·long parameters and return with a value rather than starting a new cog. What I would like is to·implement an unsigned comparison of longs. Apparently spin cannot do this natively - I have seen a passing reference on this forum indicating that it would be pretty easy to do. I have dug around (probably missed something obvious) but try as I might I cannot figure out how it·can be done.
Here's my pseudo code
DAT
·· ORG 0
UnsignedCompare:
· <assembly code here>
PUB TestCompareCall (val1, val2)
······· return UnsignedCompare(val1, val2)
All advice and assistance would be much appreciated.
DAT
·· ORG 0
UnsignedCompare:
When the Propeller starts up, it loads the "Spin" interpreter into Cog-zero. The "Spin" interpreter then runs out of Cog zero, reading "Main Memory" for the Spin tokens.
Now, Spin has a facility for starting an assembly program in another Cog. That's where you put the assembly code in a DAT section, and the COGNEW code in a "PUB start(Start_Addr, Parm_Addr)" section. The "COGNEW" call downloads the assembly section (from Main Memory, that's where "Spin" is reading tokens) into another COG. That COG then starts executing the downloaded assembly.
Now, the downloaded assembly CAN access the "PAR" register -- which holds the second parameter of the "COGNEW" call. This is so you can pass a 'shared memory' space in Main Memory that both the Spin code and the Assembly code will know about.
Also typically, in your assembly object, you'd put a few interface methods to set the variables that assembly would be watching for. When they're set, the assembly (which has been in a 'wait' cycle for them to be set) will run and put the result in yet another variable. The 'high-level' code can then return the value of that variable.
There's only 512 longs of memory in a 'Cog', so I think you MUST use an additional cog for your "math library".
Note any "Spin" methods in your assembly object (ie NOT in the "DAT" section) will remain located in Main Memory, so that Spin code can call them.
Post Edited (hippy) : 5/27/2008 2:35:03 AM GMT
First Spin is an interpreted language, besides emulators assembly execution is never done (that Im aware of) in an interpreted language. All those languages you think of that have inline assembly support are compiled languages, where your code is distilled into assembly code, so it makes it rather easy to toss some additional user written assembly in there. Interpreters operate on byte code, not assembly. Unless you create byte codes for assembly instructions (which is counterproductive) the interpretor would have no clue what to do with them.
Second, the spin interpreter resides in the memory of a cog (has to in order to be executed). There are exectly 496 locations for all instructions·and data·within a·cog. This means that the code that is executed for each and every Spin instruction must be in cog memory, not to mention the interpretor engine. Now look at the number of instructions Spin supports, it's well over 100 supported instructions. Thats an average of·less than 5 assembly instructions per supported spin instruction. This is not providing any room for the interpreter engine and some complex instructions such as multiply take·more than than·5 instructions to implement. If you looked at the code for the spin interpreter you would see instructions averaged 2-4 memory locations per supported spin instruction. IOW every single memory location is used by the Spin interpretor, and there simple is no room to "sneak" some user assembly onto the cog.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 5/28/2008 9:57:52 PM GMT
