converter movie or jpg to code?
Hi all one;
I am a new user propeller, do you know have can i convert movie to code?
Thanks for helps...
Best Regards
Thanks for helps...
Best Regards
Try this....www.propgfx.co.uk/forum/Blah.pl?b-PL/m-1211291667/
Although you will need PropGFX to play it, it will point you in the right direction.
Coley
PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
On the other hand,
http://rsb.info.nih.gov/ij/notes.html is cross platform freeware
ImageJ can convert a movie to a raw data file, which (in theory) you could write to a uSD file and then read with your Prop...
If you want full color get one of 4D's little gems.
