rf program
does the keyfobe work with the parallax rf reciever module.also if it does ,how would i program my bs2 to recieve the incoming data from the keyfob.that way i can say if this comes then do that.i know that when you hit a button on the keyfobe d0,to d5 is recieved depending on which button is pressed.if you know anything that can help me please write.
Post Edited (smartg) : 5/23/2008 9:49:59 PM GMT
Post Edited (smartg) : 5/24/2008 3:46:29 PM GMT
An encoder chip / decoder chip pair solves these problems for you. The encoder chip is attached to the 5 buttons (or maybe more) and to the radio transmitter. When any one or more button is pushed, the encoder chip makes up a message consisting of a series of pulses that somehow "encodes" the button(s) that is/are pushed and includes a numeric code (usually set at the factory inside the keyfob) that identifies the keyfob and the encoder turns on and off the transmitter in a pattern that would be recognized by a matching decoder chip and the button push and identifier number are part of the pattern transmitted.
The receiver detects the transmitted signal and produces a series of on/off pulses that go to the decoder chip which does some interpretation and checking for a valid pulse sequence, then the decoder checks the identification code against some internal switches to make sure it's correct, then puts out a logic signal on each of several pins indicating which button on the keyfob was pressed. There's usually also a "valid data" signal that is true if the button output signals are correct (the data received passed some validity checking).
It's theoretically possible for something like a BS2 to decode the "raw data" from the receiver, but the exact form of the data is not well documented and the rules for decoding it are not well documented either. I'm sure you could find it somewhere on the Internet, but it's usually easier just to buy a receiver/decoder or just a decoder chip and use that.
If you buy the combination receiver / decoder, then you do get a separate signal for each of the buttons on the keyfob and you can have the BS2 do something for each of the buttons on the keyfob. As I mentioned, you are still going to have to learn how to program the BS2 and how to get it to react to signals coming in to it like from a receiver / decoder.
