UNIX serial port won't transmit data to BS2 till after port is close
I'm trying to establish 2 way communication between my mac and the basic stamp using unix system calls to open() write() and read(). I'm using the USB BOE to transmit the data to my computer. I have had success doing the reads and writes separately but not at the same time. I would open and get a file descriptor to the device and set all the proper flags for the file descriptor but when ever I write to /dev/tty.usbserial-A4002X2A at 9600, the basic stamp doesn't actually receive the data until I close the file descriptor. I know this because I have the stamp light up an LED when it receives a byte of data through SERIN, not to mention I can see that the blue data received LED on the board iself doesn't light up until I close the connection. And because opening a new serial port connection resets the stamp, I can't open a new connection to read the reply message. Therefore it is impossible for me to send it a message and try to read it's response. I was thinking that there is some hardware buffer that isn't transmitting data until I do a close(fd) and I can't seem to find out how or why. I have even gone as far as trying to use tcflush() or ioctl() but I can't get it to work. Any suggestions or advice for a hopelessly lost fellow BS2 user? Here is my C code:
Post Edited (collegekid1) : 5/24/2008 7:33:28 PM GMT
int fileDescriptor = -1;
struct termios options;
const char *deviceFilePath = "/Dev/tty.usbserial-A4002X2A";
fileDescriptor = open(deviceFilePath, O_RDWR | O_NOCTTY | O_NDELAY);
if (fileDescriptor == -1)
printf("Error opening serial port %s - %s(%d).\n",
deviceFilePath, strerror(errno), errno);
goto error;
if (fcntl(fileDescriptor, F_SETFL, 0) == -1)
printf("Error clearing O_NONBLOCK %s - %s(%d).\n",
goto error;
if (tcgetattr(fileDescriptor, &options) == -1)
printf("Error getting tty attributes %s - %s(%d).\n",
goto error;
cfsetispeed(&options, B9600);
cfsetospeed(&options, B9600);
//using raw input
options.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG);
//set character size and control flow
options.c_cflag |= (CS8 | // Use 8 bit words
CCTS_OFLOW | // CTS flow control of output <-----PROBLEM HERE DON'T SET HARDWARE CONTROL FLOW
CRTS_IFLOW); // RTS flow control of input <-----PROBLEM HERE DON'T SET HARDWARE CONTROL FLOW
//no parity
options.c_cflag &= ~PARENB;
options.c_cflag &= ~CSTOPB;
options.c_cflag &= ~CSIZE;
//Enable the receiver and set local mode...
options.c_cflag |= (CLOCAL | CREAD);
//disable software flow control
//options.c_iflag &= ~(IXON | IXOFF | IXANY);
// Cause the new options to take effect immediately.
if (tcsetattr(fileDescriptor, TCSANOW, &options) == -1)
printf("Error setting tty attributes %s - %s(%d).\n",
goto error;
char writeBuf1[noparse][[/noparse]] = "2";
int written;
if((written = write(fileDescriptor, writeBuf1, 1)) == -1)
printf("Error writing data - %s(%d).\n", strerror(errno), errno);
goto error;
printf("\nBytes written: %d\n",written);
printf("\nDone writing data...\n");
program on the stamp hasn't received any data at this point so I can't try to read a reply message
close(fileDescriptor);
- Stephen
