new OS - PorthOS is born - Now with copy and .bat support
Hi all.
I'm writing my own operating system for the prop, called PorthOS. Its basically a plagiarized version
of propDOS by OBC, and at the moment very similar to it, with only a couple of differences. Many thanks
to OBC , Mike Green and Paul H for their permission to use their code.
Current features:
*a few dos commands (dir, erase, type, cls, help, ver, copy)
*error checking with the delete file command
*uses standard TV text object by parallax instead of the small fonts, which is good or bad,
depending on how good your eyesight is. mine is terrible, which is why i wanted
something easy to read.
*the HELP command lists all valid commands, which is handy for those with bad memory
*to launch a binary, simply type its name with or without the extension
*a slow but working Copy command <-- new
*.bat batch file suppport <-- new
*command line argument passing <-- new
Future plans:
config file so apps know what hardware is installed and where. maybe i'll get smart and figure out a way to utilize dynamic drivers
please download and enjoy and let me know if you find any bugs or
want to see some feature implemented.
Post Edited (vampyre) : 5/25/2008 10:41:12 AM GMT
Current features:
Future plans:
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
My kids are visiting for the summer so progress will slow a bit, but in just an hour this morning i was able to get the command line argument passing done and write a test app that shows how to make use of it. maybe thats not a big accomplishment but keep in mind, i've only been spinning for what, a week? and up till this point, i haven't drawn a single flow chart. I should have, but the fact that i was able to get this far without any real planning is.. mind boggling. The prop, and language are just superior products. i can't wait till the rest of the world realizes that.
This release contains:
BATCH file suppport
and command line argument passing
this file is attached to the first post in this thread
Hope u guys find it useful
