Blast or Confirm this theory..
Been mulling a communications theory around for the last year,
posted here to either blast or confirm, (or possibly point out that
it has already been designed)
Preface.. Computers communication via 1's and 0's (on/off)
The speed of the communication being how fast we can toggle them,
as well as how many 1's and 0's we can send at a time. (bus width)
What if ADC's were used to communicate voltage ranges
instead of 1's and 0's? We could "say" more with fewer
physical connections. 10% voltage is one thing, 20% another.
Is this type of communication in use already? Nutty idea?
or OBC has seen into the future?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
OBC
"Kinda-sorta" along the same lines, a similar idea with transmitting light of a specific color through optical fiber to represent different types of data does exist. To transmit one of seven conditions, a bright RGB LED is focused into a length of optical fiber and a color sensor on the other end interprets the condition for a controller. So these "data types" are available as a "single data bit":
0=all off
1=red
2=green
3=blue
4=red and green
5=red and blue
6=green and blue
7=all 3 on
The LEDs are driven with a constant current source to prevent brightness levels becoming a factor in the color when using more than one LED. The "smart" transmitter consists of about 7 parts.
~~ dRu ~~
It's called QAM (Quadrature Amplitude Modulation), and is commonly used.
en.wikipedia.org/wiki/Quadrature_amplitude_modulation
Depending on the number of constellations, you can have 4-QAM, 8-QAM, 16-QAM, 32-QAM, etc. different amounts of throughput can be achieved with relatively low bandwidth requirements.
en.wikipedia.org/wiki/Constellation_diagram
Digital Cable TV I think uses a 64-QAM technique.
Although I'm not sure nowadays, but in the early 80's and 90's this technique was widely used for telephone modems and cause for the "boom" during that period where the throughput doubled over the same copper wires in a relatively short time.
Ethernet communication uses a form of this to obtain reasonable high speeds over copper, but it phases the signal over the 4-pairs. I.e. for Gigabit Ethernet, each twisted pair only has a throughput of 250kbit (1/4th of the Gigabit), then QAM is applied to each twisted pair so that a throughput of at least 250kbit is achieved on each pair. Depending on the constellation patterns used via QAM (can be variable) the actual bandwidth through the Ethernet cable can be quite low.
Scroll towards the bottom of this page under the description for "1000BASE-T details"
en.wikipedia.org/wiki/Gigabit_Ethernet
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 5/22/2008 12:14:45 AM GMT
Comments have inspired me to add some experimentation on this
to my "to-do" list! I could see a neat project for the multicolor LED setup.
Good reading in links! Thanks Guys!
OBC
Not directly related to this thread, but it did prompt a trip to the Electronics Exchange.
I think the link in your signature area does not have it as www.warrantyvoid.us, so the link fails and has to be manually entered.
Cheers,
Tom Sisk
http://www.siskconsult.com
OBC
